Vinal Siding Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 06:12 PM   #1
Vinal Siding repair
I want to remove vinal siding on a porch to check for possible wood damage. How can this be done without damaging the vinal siding? If so, what are the steps I need to take for the removal.
artie406 is offline   Reply With Quote
Old 10-31-2010, 06:17 PM   #2
There's quite a few video's on youtube that will show you how to do this. It's pretty simple and may seem harder than it is. There is a tool for unhooking the overlapped siding....but can be done without it. It's not bad at all.
169stang is offline   Reply With Quote
The Following User Says Thank You to 169stang For This Useful Post:
artie406 (11-01-2010)
Old 10-31-2010, 09:33 PM   #3
Household Handyman
Rewards Points: 1,408
This is not a hard job to do, and as stated there is a special tool for "unhooking" the siding from each other. These are inexpensive and worth their weight in gold when needed. One suggestion: As you remove each piece, either number them or stack them so they go back exactly where they were removed. Ask me how I learned this one. David
The Following User Says Thank You to Thurman For This Useful Post:
Old 11-01-2010, 02:35 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Those tools are pretty easy to find, even the box stores carry them. Vinyl siding can take a beating as long as its not very cold out, so you shouldn't have any probs. Just be sure to follow Thurman's advice and keep track of the order that they were removed unless they're all cut the same.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 11:55 AM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
OSB Panel Siding: Repair or Replace SirDieAlot Building & Construction 5 06-03-2008 09:19 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
