VERY Basic Ceiling Framing Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 08:53 AM   #1
artlover13060's Avatar
VERY basic ceiling framing question
I need to frame a hall ceiling in a basement for drywall. The hall is 8' X 3' and opens to other rooms without header at both ends. The walls are already finished.
I plan to nail a 2 X 4 along the two long walls and use 2X4s on 16" centers across the 3' span. What is the best and easiest way for an amateur to attach the short 2X 4s to the 8' nailers? There is a heating duct directly above so I will have no headroom to work in. I thought of using joist hangers but there won't be room to maneuver the 2X4s into place. I seriously doubt my ability to toenail the 2X4s and sink the screw heads.
artlover13060 is offline   Reply With Quote
Old 12-28-2009, 09:02 AM   #2
predrill holes in ends of 2x for nails or screws
Old 12-28-2009, 09:14 AM   #3
Old School
Willie T's Avatar
This is a lot of extra work, but you COULD do it this way.
Cut your 2 x 4's 1" short.
Make a bunch of 1/2" plywood extensions like those shown.(7 1/2" x 1 1/2")
Nail on to each end of the 2 x 4's.
Then nail the 2 x 4's in place by nailing through the plywood extensions.
(The second window shows it rigged to install on edge... with 3 1/2" x 5 1/2" extensions.)
VERY basic ceiling framing question-short-2x4.jpg   VERY basic ceiling framing question-short-2x4-2.jpg
Willie T
Old 12-28-2009, 09:42 AM   #4
Willie T, I see how that would work and it is doable, but does sound like a lot of extra work.
Tpolk, where would be predrilled holes be located? At an angle to allow easy toe nailing?
Old 12-28-2009, 10:45 AM   #5
Old School
Willie T's Avatar
It certainly is a LOT of extra work. Toenailing takes about 5 seconds per nail.
Willie T
Old 12-28-2009, 11:20 AM   #6
Rewards Points: 1,016
Plan A: Try toe nailing (yeah, you can do it)
Plan B: Willie T's idea of adding a plywood nailing flange
Old 12-28-2009, 11:43 AM   #7
plan C predrill holes at angle so nails are alredy placed when you put material in place and arent wrestling with nail,hammer and piece
Old 12-28-2009, 12:36 PM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Put joist hangers on one wall only. Slip one 2x4 into place and slide the other hanger up over it. Nail it into place.
Old 12-28-2009, 01:03 PM   #9
Registered User
Rewards Points: 5,492
Build the 3x8 ladder unit on the floor first, face nailing. Nail a temporary scrap block on wall, thickness of ladder shy, down at one end only. Raise ladder horizontal with one end on block, nail off. Use proper layout for objects.
Be safe, Gary
Old 12-28-2009, 01:43 PM   #10
Old School
Willie T's Avatar
Be safe, Gary
Hey, Gary... did someone start building straight and square hallways out there? They sure don't around here.
In these parts, it might work if you built it 3/4" narrow, and shimmed it all the way.
Willie T
Old 12-28-2009, 04:45 PM   #11
There is nothing square about this house. I swear they had monkeys on the building crew.
Old 12-28-2009, 04:56 PM   #12
firehawkmph's Avatar
Rewards Points: 1,868
Art,
Nail up the 2 x 4 frame around the perimeter. Now take the 5, yes only 5 short pieces of 2 x 4's and predrill each end with two holes on an angle. Now use 3" deck screws and screw them in with a cordless impact or cordless drill, or worse come to worse, an electric varialble speed drill with a cord (aauugghhhhhh!). I am being a little facetious, but c'mon, you aren't framing in a house here. This job should take about a half hour, including coffee.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 12-28-2009, 05:21 PM   #13
1/2 hour? damn where did i set the screws... crap the drills on the floor...
Old 12-28-2009, 05:53 PM   #14
Registered User
OK, I forgot to mention do a short 3-4-5 diagonal in the corner or hold up that rip of 2x6' piece of 1/4" with the factory edges to the walls.....
You still have a 66% chance it will fit. It will rack easily, just not shrink on both ends.... Post your location, send me air fair, it's pretty slow here.
Be safe, Gary
Old 12-28-2009, 06:51 PM   #15
OK,Post your location, send me air fair, it's pretty slow here.
Be safe, Gary
LOL, Gary. I wish I could do that. My #1 Christmas wish was for a carpenter to help me with my remodeling.
Another popcorn ceiling question! HOW? Astrovel Painting 21 11-12-2010 09:19 PM
Exterior wall framing question Pmatyj01 Carpentry 5 10-04-2009 01:09 PM
Balloon Framing Question zetti1102 Building & Construction 2 09-30-2009 09:50 PM
Garage Framing Question wrldruler Building & Construction 5 08-22-2008 08:26 AM
Ceiling Insulation Question cabinetman General DIY Discussions 6 06-04-2007 12:22 PM
