Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-21-2012, 11:11 PM   #1
veneer plywood (delaminating)
is it normal for birch/maple veneer plywood to start delaminating simply from spending 2-3hrs in a dry garage(60+degree) while,it was sprinkling rain outside! I have never had anything happen like that before. I did not inspect for popped veneer.I think it may have been like that when I bought it. (lowes) thanks! for any input. whew!! newbie
realistic is offline   Reply With Quote
Old 09-21-2012, 11:13 PM   #2
Normal no, but ha it's real wood anything can happen.
realistic (09-21-2012)
Old 09-21-2012, 11:20 PM   #3
nope!
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Old 09-23-2012, 12:02 AM   #4
Cabinet maker
Augie Dog's Avatar
Take it back. It is defective.
Augie Dog is offline   Reply With Quote
Old 09-27-2012, 07:24 PM   #5
I agree, it's defective.
Of course, I would say the same thing had you just said, "I bought some plywood at Lowes."
I know it's rarely as convenient, but I'd look around for a better source of lumber, especially sheet goods. There can be significant differences in the veneer and adhesive quality between big box store products and other sources. And for some reason, the higher-quality lumber isn't more expensive.
zakany is offline   Reply With Quote
Old 09-27-2012, 07:48 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
that only happens when its been wet for extended periods of time or it was abused during transport
woodworkbykirk is offline   Reply With Quote
Old 09-27-2012, 10:04 PM   #7
Cabinet maker
Augie Dog's Avatar
I respectfully disagree.
We have had problems with panels de-laminating for no other reason than the lack of glue between veneers.
Every mill has production problems like this from time to time. It is usually limited to a a short period of time in the plant but it happens and it sucks when it does.
It helps to have a good relationship with your supplier during times like that.
Old 09-28-2012, 11:21 AM   #8
I managed a lumber yard, we used to buy the stuff delaminated, well some of it would be, got a really good price on it.
Plywood sub floor in bathroom-dry rot or delaminating? incognito_wife General Discussion 3 04-28-2012 01:48 PM
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 3 05-15-2011 02:45 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 1 11-09-2009 05:29 AM
