Vaulted Crown Molding - HELP! - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-23-2007, 07:13 AM   #1
Folks - I'm new to forum, not sure this is addreessed somewhere but I am having a hard time hanging crown molding in a vaulted or catehedral ceiling, Geometry was never my strong suit. I have read several articles on several different ways to do it, but I'm looking to see if anyone has a "trick of the trade" if you know what I mean.
I also have the cut-n-crown jig system, but the DVD really doesn't explain it that well. If someone has used this system to hang it - let me know. http://www.cutncrown.com
Any advice or solutions would be helpful.
normanr is offline   Reply With Quote
Old 08-23-2007, 08:47 PM   #2
zel
Rewards Points: 150
Send a message via AIM to zel
I cant directly help, but a few weeks ago someone mentioned a book that is supposed to help with crown on vaulted ceilings. Do some searching and you should find it. Good Luck.
zel is offline   Reply With Quote
Old 08-24-2007, 02:53 PM   #3
Crown moulding has reduced many a person to tears, add yet another angle, a vaulted ceiling, and many professionals will take it slow. Here is something you might want to check out:
http://www.compoundmiter.com/
I got the book and the true angle tool at Home Depot. That said it took me forever to get the hang of it and I'm sure a pro would laugh. Just keep going slow. No walls are true there will be a lot of fine tuning.
Concordseeker is offline   Reply With Quote
Old 08-30-2007, 03:16 PM   #4
oak
gary katz's video covers it...
http://www.garymkatz.com/publications_dvds.html
they can be rented from smartflix.com if you dont want to buy it..
oak is offline   Reply With Quote
Old 08-30-2007, 03:18 PM   #5
oak
and here is a free article by gary..
http://www.garymkatz.com/TrimTechniq...ansitions.html
Old 07-03-2009, 08:47 AM   #6
I have am about to order cut N crown Jigs Did they perform as advertised on the ceiling that was not vaulted. I have a small 10" compound miter saw will the jig fit on the table?
pbprj3 is offline   Reply With Quote
Old 07-03-2009, 08:55 AM   #7
Insalling Crown Molding
Anyone who has used Cut N Crown. Are the Jigs worth $40 each? Would you recommend anything else? I have a 10" compound miter saw and I can"t use the Bench Dog because the housing on my saw will hit when I miter right side. And I can't use 5" molding unless I lay it flat. Is there an easy way to lay it flat and cut for vaulted ceilings? All help will be appreciated. I am new at this but look forward to trying. Thanks all
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 06:51 PM
Painting crown molding greeniemom Painting 6 02-26-2008 02:26 PM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 07:13 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 01:34 PM
Crown Molding Ramblnmn Remodeling 3 10-24-2006 09:08 PM
