Vauled Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 08:26 PM   #1
Rewards Points: 212
Question
vauled ceiling
when framing a vauled ceiling, what should the specs. for the ridge be? should it be able to hold half the roof load since the ceiling joists are no longer and sitting on the walls to keep the rafters from going outward?
bluebird5 is offline   Reply With Quote
Old 03-01-2011, 09:27 PM   #2
Correct The ceiling joists are not there to act as collar ties and the beam size would be calculated for half the load with bearing point loads on the ends. The other half would sit on the walls. Get an engineer SVP
masterofall is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
