Varnished Wood Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 11:39 PM   #1
varnished wood cabinets
is there a product that can be used/applied to rough the surface of varnished wood for painting other than sanding?
tgarlington is offline   Reply With Quote
Old 06-19-2012, 12:23 AM   #2
I'm not aware of any chemical method that would not also require sanding.
Evstarr is offline   Reply With Quote
Old 06-19-2012, 12:30 AM   #3
Too Short? Cut it Again!
There are chemical de-glossers and surface prep agents but they are expensive and in my opinion not as effective as good old cheap sandpaper. Even if they did work, they would not save you that much time.
Old 06-19-2012, 07:51 AM   #4
deglossers
could you shoot me a few names of some deglossers you would recommend
Old 06-19-2012, 08:02 AM   #5
Your real paint store will have a brand that works well. I really did not like the stuff so have no recollection of brand names. It is solvent based so make sure you have adequate ventilation.
The Following User Says Thank You to user1007 For This Useful Post:
tgarlington (06-19-2012)
Old 06-23-2012, 07:15 PM   #6
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Sand it by hand with 100 grit, use a pinwheel sander lightly in a drill to get into the tough parts, give it a coat of "Kills" maybe two.... sanding everything between coats...then a top coat and that should do the trick.
Varnish is hard stuff......it might be polyurethane or conversion lacquer.....use the same process
"Kills" is a mineral based undercoat and will take water based top coat
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
The Following User Says Thank You to woody4249 For This Useful Post:
tgarlington (06-23-2012)
Staining Help Needed! I finished my Red Oak Kitchen Cabinets and they look horrible!! mojavekat Painting 14 04-10-2013 06:39 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 03:23 PM
Do you wanna buy the wood kicthen cabinets from China? Dwyane Wade.cn Building & Construction 3 08-13-2009 07:56 AM
when painting wood trim and cabinets oldrivers Painting 3 07-15-2009 04:13 PM
