Various Ongoing Built-in Construction Questions. - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 08:30 PM   #16
Rewards Points: 588
Sounds like I will have to use a 1/3 of a $45 sheet of 3/4 ply to make 4 and 8' jigs just to start......
noone is offline   Reply With Quote
Old 02-29-2012, 08:35 PM   #17
DIY staff
Rewards Points: 7,174
Any really straight board will do----no need to spend big bucks --look through the pine 1x6 or 1x4 and see if you can find a perfectly straight one---
Old 02-29-2012, 08:38 PM   #18
DIY staff
The wood you choose for your face frames could be put to work while you make the boxes--then used for the face frames--if you use clamps with rubber covers when you clamp the 'jigs' the wood should be fine for the face frames---
Old 02-29-2012, 08:39 PM   #19
Rewards Points: 588
Ive seen that pine stock before and I have no idea how I'd find a piece that was 8ft perfectly straight! I'm not even sure how to test that since the home depot floor is most likely not flat. Guess I'm just over analyzing everything. I'm a planner.
Old 03-01-2012, 06:19 AM   #20
DIY staff
Yep---sound like it!---
I use my eyes---just site down the edge of the board---like choosing a pool cue at a tavern---
how hard is it to built built in shelves? abefroman Carpentry 8 01-02-2012 08:15 PM
Trying to update 60 year old basement/crawl... many issues & questions billyh Insulation 1 03-24-2011 12:07 PM
Structural questions WillK Building & Construction 6 01-13-2011 08:10 AM
built in or built under ovens anastacia Appliances 4 02-09-2010 08:03 AM
built under oven as a built in one? helen30 General DIY Discussions 3 01-27-2008 03:15 PM
