Varathane On Top Of Lacquer - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 06:48 PM   #1
Varathane on top of Lacquer
I had a kitchen table given to me. It has a lacquer finish... Pain in the but because u put a glass on it and it stains. I want to put varathane on it for protection from stains and generally i want to be able to put a beer on it without an issue. Should i lightly sand it and varathane it? Or would there be a better solution?
Thx
fjacky is offline   Reply With Quote
Old 01-13-2012, 06:51 PM   #2
DIY staff
Rewards Points: 7,174
I've seen polly lift lacquer like a paint remover---Do a test---
Old 01-13-2012, 06:56 PM   #3
Rewards Points: 13,694
Strip it and put three coats of poly on it.
Old 01-14-2012, 09:48 AM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
Lacquer strips with lacquer thinner. Unlike polyurethane, lacquer can be "reactivated" when it comes into contact with the proper solvent.
Millertyme is offline   Reply With Quote
Old 01-14-2012, 05:42 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
yup, you'll have to use stripper first then give it a light sand before you recoat it. you have to make sure you get rid of all the old lacquer to ensure there is no uneven color and proper curing
woodworkbykirk is offline   Reply With Quote
Difference between Paint thinner, Lacquer thinner, Naptha, Acetone and alcohol? cousindan Painting 5 05-02-2011 10:57 AM
Chip in lacquer woodsey Interior Decorating 0 02-08-2011 07:14 PM
applying lacquer jpmoran3 General DIY Discussions 4 12-12-2009 08:36 AM
polyurethane over lacquer????? fricandfrac Flooring 5 09-07-2009 10:18 AM
Sanding in between Varathane water based floor finish? Joony Flooring 1 07-09-2008 07:10 AM
