Utility Room Shelving - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 06:53 PM   #1
Utility room shelving
I've built an open storage cabinet 6' H x 2' W x 1' Deep, out of 3/4" thick pine. I attached a thinner wood panel to the back for sturdiness. I plan on installing four slotted standards (metal strips) inside so I can support the shelves.
I have two questions:
1. Will that hardware be strong enough to support 3/4" thick laminated presswood shelves PLUS cans of paint, detergent bottles, etc. on top? The shelves themselves are kind of heavy. Or there is a better way to support the shelves ...
2. How do I brace the cabinet to my stucco wall so it doesn't fall forward?
Any suggestions will be greatly appreciated.
DianaInWPB is offline   Reply With Quote
Old 07-27-2011, 07:16 PM   #2
Framing Contractor
Rewards Points: 118
I think those clips will hold up ok for what you need. You can add a 1x2 under the front edge of each shelf to beef them up a bit. Install a 1x2 ledger under the top shelf and screw it into a couple studs in the wall to prevent tipping.
sixeightten is offline   Reply With Quote
Old 07-28-2011, 07:50 AM   #3
Rewards Points: 5,336
I used these standards for mobile storage units in the garage. They are stacked with power tools and have held up for 15 years.
Ron
B. Franklin 1759
Old 07-28-2011, 12:05 PM   #4
Thanks, SIXEIGHTTEN and Ron6519, for your very valuable advice!
Now I can order those standards with confidence and I can apply to my project what I've learned from you both.
Old 07-28-2011, 12:16 PM   #5
Local big box stores carry these in stock.
Ron
B. Franklin 1759
Old 07-28-2011, 02:46 PM   #6
Thanks again, Ron.
There are two such "big box stores" near me. I will check them out.
Old 08-03-2011, 10:53 AM   #7
Originally Posted by TomKinley1 View Post
I think double-slotted standard is also beneficial for your project. It is easy to installation and adjustability.
Thanks, TomKinley1, for the suggestion. I thought about those double-slotted standards afterwards. We are lucky to have so many alternatives for our DIY projects and we are lucky also to have a forum like this where everybody tries to help.
Thanks again.
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Laundry Room Addition Completed hyunelan2 Project Showcase 6 02-27-2011 10:42 PM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 11:44 AM
sound proofing utility room BlueBSH Drywall & Plaster 29 12-24-2009 12:44 PM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 05:30 AM
