Using Regular 1x8 As Baseboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 06:47 PM   #1
Rewards Points: 1,062
Question
using regular 1x8 as baseboard
since i have a deep rooted hatred for anything beveled or routed grooves or any "aesthetic" form that serves no utilitarian purpose, i want to replace my baseboards with something so simple that can't be simpler. so would the cheapest 1xX lumber work, if painted?
thanks
Old 01-28-2011, 06:50 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You can use whatever you want to use. If you don't want to use anything fancy, it's your house.
At my dads house there is no baseboard per se. He has hardwood floors and has 1/4 round simply to cover the gap between the floor and the wall.
The Following User Says Thank You to nap For This Useful Post:
amakarevic (01-28-2011)
Old 01-28-2011, 06:54 PM   #3
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
1x8 may be a little deep. 1x6 would be more like it, but it depends on the other trim in your house. If you don;t have crown, go w with something minimal like 1x3 or 1x4. If you have 7" crown, go with 1x6.
And work on the hatred part.
WirelessG is offline   Reply With Quote
Old 01-28-2011, 07:02 PM   #4
Smile
there will be no crown. the floor is carpet. i want no crown and maybe, maybe the simplest molding if just 1x6 or 8 looks too bare. i think i like slightly higher so i might go 1x8.
thanks. hatred ? i just can't stand anything beyond minimalism in aesthetics, sorry ... extra work, visual pollution.
Old 01-28-2011, 07:09 PM   #5
Registered User
Rewards Points: 5,216
I feel a solid board will cup and twist if you have high humidity. At least cut relief grooves in the back to help is stay straight with the seasonal changes. I used 3/4" plywood for my addition baseboards and added 1/4 round shoe to keep the old style look. Better than the MDF on the market.....
Gary
The Following 5 Users Say Thank You to Gary in WA For This Useful Post:
fungku (01-29-2011), gma2rjc (01-30-2011), oh'mike (01-28-2011), Tom Struble (01-29-2011), Willie T (01-29-2011)
Old 01-28-2011, 07:49 PM   #6
WirelessG's Avatar
Rewards Points: 698
Gary
Good point, Gary.
Old 01-29-2011, 05:47 AM   #7
Gary
Painting both sides of the trim will help prevent it, too.
almostnormal is offline   Reply With Quote
The Following User Says Thank You to almostnormal For This Useful Post:
Old 01-29-2011, 02:25 PM   #8
i went to HD last night and i think i'm gonna use maple 1x6, it's about $2.5 per foot, which is reasonable. i shouldn't need more than 60 ft.
Old 01-29-2011, 06:22 PM   #9
I just used 1x6 poplar in three bathrooms I just remodelled. Customer didn't want any moulding on the top, so I used a plane with a rounding blade to take the arris off the edge
mrgins is offline   Reply With Quote
Old 01-29-2011, 08:33 PM   #10
Contractor - Renovations
fungku's Avatar
1x8, 1x6 whatever. It is fine. You can always build it up later and add a base cap.
1x8 is fairly large, but if you have really high ceilings and large crown then it could work.
Large crown and small base looks funny, and so does small crown and large base.
fungku is offline   Reply With Quote
Old 01-29-2011, 08:40 PM   #11
firehawkmph's Avatar
Rewards Points: 1,822
thanks
So what kind of car do you drive, an old checker cab? Why would you pay 2.50/ft. for maple when you can buy poplar for less than half the price? Maple is more aesthetic and serves no utilitarian purpose over poplar.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-29-2011, 08:51 PM   #12
Old School
Willie T's Avatar
So very, very true!
Willie T
Old 01-29-2011, 08:55 PM   #13
Old School
Willie T's Avatar
Originally Posted by mrgins View Post
... so I used a plane with a rounding blade to take the arris off the edge....
Not many people even KNOW that architectural term, let alone use it. Sharp! (not to make a pun...)
Willie T
Old 01-29-2011, 09:46 PM   #14
Experienced
Jackofall1's Avatar
Mike Hawkins
TooShea!!!!
And then paint it to boot.
Old 01-29-2011, 10:47 PM   #15
Tom Struble's Avatar
Rewards Points: 2,002
i'm still trying to figure out whats so ''minimalist'' about a 1x8 base board
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
fungku (01-29-2011), Willie T (01-30-2011)
Electric Baseboard Heater Questions mark2741 HVAC 0 12-31-2010 01:08 PM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
