Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-03-2012, 11:39 PM   #16
yummy mummy's Avatar
Using OSB board to make a headboard?
Originally Posted by woodworkbykirk View Post
unless your going to build a frame for the 3/8 plywood to be installed to . 3/8 alone wont have any strength unless of course you fasten it directly to the wall first... its thin plywood that will continue to bend and move on its own. you need at least 1/2"
Next time I will use 1/2 inch. I am going to hang it on the wall.
yummy mummy is offline   Reply With Quote
Old 04-04-2012, 08:25 AM   #17
I built a perimeter frame from 2x2 and put a couple support posts in the middle and screwed the 7/16 OSB to the framework. Then bolted the 2x2 legs to the bedframe. Works very well.
dwcopple is offline   Reply With Quote
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 10:13 PM
GMP075-3, Bad Board?? RaySuave HVAC 2 12-12-2011 11:02 AM
Green board, blue board, backer board??? ddougee Remodeling 5 03-21-2011 10:58 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 05:46 PM
