Using OSB Board To Make A Headboard? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 08:11 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Using OSB board to make a headboard?
I plan on using osb boards to make an upholstered headboard.
I was wondering if it is ok to use osb as a headboard (will be painted first and then covered in fabric) and if it is safe in terms of breathing and if the glue that is used on the boards is ok to use inside homes.
It is for my teenager babies bedrooms......lol
yummy mummy is offline   Reply With Quote
Old 03-26-2012, 08:16 AM   #2
Too Short? Cut it Again!
Glue is cured under pressure so you should be fine. All building materials outgas to some extent though. You would have similar adhesives with plywood. Of course, make sure there is no chance of moisture getting at the OSB. If you are cushioning under the fabric I would be more concerned about what adhesive you use for that the glue in plywood or OSB. And speaking out of total paranoia post December fire in the building? Make sure to treat the fabric with a fire retarding agent. Foam and fabric flash combust in a hurry.
Old 03-26-2012, 09:40 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
I would not suggest it....your going to have issues getting screws and nails to stay in it as compared to plywood...and it's reall hard to glue....
ddawg16 is online now   Reply With Quote
Old 03-26-2012, 01:25 PM   #4
Thanks sdsester for the great information. I really appreciate it. Also for the fire retarding agent suggestion.
I will only be using a staple gun to adhere the fabric.
You are wonderful sdsester! You have great advise.
Old 03-26-2012, 01:27 PM   #5
Thanks for your information. I hope I can get the staples to go through. I am not planing on using any nails, and only a light spray adhesive just to hold the foam in place.
Old 03-26-2012, 01:30 PM   #6
Just a DIY guy
Have you smelled OSB? It's not the greatest smelling thing, and it's going to be right next to your son's head.
I don't know if paint will seal in the smell or not. For the minimal difference in cost, I'd use plywood.
M3 Pete is offline   Reply With Quote
Old 03-26-2012, 01:37 PM   #7
Rewards Points: 13,758
3/4 plywood would be a far better choise.
OSB is not going to hold staples.
Old 03-26-2012, 11:40 PM   #8
Registered User
Rewards Points: 5,520
The OSB I've put on walls since the 80's has always stunk, never plywood. Floors, walls and roofs- never have gotten used to the (choking) aroma from the product. Way different than plywood, go to a box store, lift a corner 1/2" high, let it down and breathe in......
Gary
Old 03-27-2012, 08:44 AM   #9
Yes, I have smelled the OSB boards and I don't like it. I was thinking that it would go away after a while?
And if I covered it with fabric that the smell would not be there.
I did not know that osb had such a gross smell. Oh, well, I guess I will trash the ones that I bought and go and purchase plywood instead, and if the staples won't go in, then I need to change it.
Thanks very much to everyone for your great advice.
What would I do without you guys and dolls...
Old 03-27-2012, 08:59 AM   #10
the Musigician
DangerMouse's Avatar
You shouldn't have any problems stapling using birch plywood. It's soft enough for that, especially if you use shorter staples (1/4") and be sure to hold the gun tight to the surface when setting the staples. Also, I'd go with 1/2" plywood if excess weight is a concern, it'd more than do the trick for you. Keep a tack hammer handy just in case a staple does not go far enough..... and use longer staples for multiple layers of fabric, of course.
DM
Old 03-27-2012, 09:55 PM   #11
Thanks danger. I am going to go with 1/2 inch. The piece will measure 56 X 36 inches. I hope it's not that heavy.
Old 04-03-2012, 07:29 AM   #12
Rewards Points: 99
We made one out of OSB for our King bed last summer. It turned out awesome. Used an air stapler to attach the batting and fabric. No problems in nearly a year now. No smell whatsoever either. I'd suggest it as it is far cheaper than ply.
dwcopple is offline   Reply With Quote
Old 04-03-2012, 02:56 PM   #13
I wanted to be safe so I purchased 3/8ths inch plywood. Now if I only could get it straight.....lol It has a little bow in it.
I am going to use a hand stapler. Don't have an air stapler.
Did you put in upholstery tacks? I would like to try, but I don't think I can make them all look even.
Old 04-03-2012, 04:04 PM   #14
Rewards Points: 99
nope, wrap, tuck and staple.
Old 04-03-2012, 07:29 PM   #15
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,218
unless your going to build a frame for the 3/8 plywood to be installed to . 3/8 alone wont have any strength unless of course you fasten it directly to the wall first... its thin plywood that will continue to bend and move on its own. you need at least 1/2"
woodworkbykirk is offline   Reply With Quote
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
GMP075-3, Bad Board?? RaySuave HVAC 2 12-12-2011 10:02 AM
Green board, blue board, backer board??? ddougee Remodeling 5 03-21-2011 09:58 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Why not remove kneewall batting and replace with foam board? fdecker Building & Construction 1 10-20-2010 04:46 PM
