Using Circular Saw Blade In A Chop Saw - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 03:19 PM   #1
Using circular saw blade in a chop saw
Hi and I thank you in advance for your answers.
I am installing HardiePlank cement board siding. I was using a 10" chop saw to cut the cement boards with a carbide tipped blade. This was not good, to much dust and the blade wore out very quickly.
A new diamond 10" blade for the chop saw is very expensive. And so is the cutter, which does not work very well.
I have a 7 1/2" diamond circular saw blade made specifically to cut the HardiePlank in a circular saw, which rotates opposite a chop saw.
Can I install the 7 1/2" saw in my chop saw backwards, so it rotates correctly. It looks like it would work fine. I don't need a lot of cutting width.
I would like to know if anyone has ever installed a circular saw blade in a chop saw before.
Thanks, Ray
rayem723 is offline   Reply With Quote
Old 10-22-2008, 03:35 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Never have done it. I would pay close attention to the rpm rating of the saw blade vs the speed of the chop saw. If I had to guess, I would say that it wouldn't be very safe. The miter saw rating is more than likely calibrated on a particular size saw blade and anything else might not be very safe. As far as turning it backwards, it doesn't matter when I put a conventional saw blade on my left hand circ saw.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 10-22-2008, 04:25 PM   #3
Contractor - Renovations
fungku's Avatar
The angle of the carbide tips for cutting is different on a chop saw than for a circular saw for obvious reasons.
if the arbour sizes matched, then you could probably do it, and it may work okay.
However, I just wouldn't do it. Use the right tool for the right job. Anytime you don't you are compromising your safety.
fungku is offline   Reply With Quote
Old 10-22-2008, 06:24 PM   #4
Works like a charm with no problems. Used it all afternoon.
Mounted a 2 X 10 on the base of the chop saw in order for the blade to cut through a 5 1/8 cement board.
Hooked up a shop vacuum to the dust port to catch the dust the blade puts out.
Cuts like cutting butter. Does not feel unsafe.
Ray
Old 10-26-2008, 03:08 AM   #5
Lansing's Avatar
Ok I thought about it...So yes you can do it...The dust on that product is a killer but the shop vac is a good idea...
When the time comes for you to leave this world
the only thing you get to keep is what you gave away...
Lansing
Lansing is offline   Reply With Quote
Old 10-27-2008, 09:08 PM   #6
dewalt makes a blade the cut masonary for about 15.00 and it works for backer board and the board you are using is made by the same company it will work and ware a dust mask I hate that stuff regards Rob
super carpenter Rob is offline   Reply With Quote
circular saw rpm-is that the motor or blade rpm? airpwr1@graceba.net Tools 13 06-28-2009 07:28 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
ripping safely with a circular saw bobbyC777 Safety 6 02-20-2008 10:16 AM
What saw blade do you use to cut soffits? Malcolm Roofing/Siding 3 06-14-2007 12:48 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
