Used Vinyl Windows With Broken Nail Fin - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 04:16 PM   #1
used vinyl windows with broken nail fin
i am building a 192sf building and want to use vinyl windows that were removed from my home and the nail fins were cut off in the removal. can these be installed and made waterproof. there are 4 double hung and 1 slider. please use simple language as i am just learning to build and do not have all the terminology.
babybuilder is offline   Reply With Quote
Old 10-13-2010, 06:22 PM   #2
kwikfishron's Avatar
Rewards Points: 368
Yes you can.
Think about a old single hung window with a sloped sill. Those sashes are held in with wood stops within a wood frame.
You would install your windows the same way. You would need to build a frame with a sloped sill and install your windows within that frame sandwiched between 1x stops on the inside and out.
kwikfishron is online now   Reply With Quote
White Vinyl Windows with wood trim-hate it melindajanczur Interior Decorating 5 10-26-2009 09:33 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
Window Casing around Vinyl Windows tcoshea Building & Construction 3 11-28-2007 09:52 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
