Use Bolt To Sister Studs? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 03:47 PM   #1
Rewards Points: 31
use bolt to sister studs?
Hi all
When sistering 2x4 vertical wall studs, are 3" nails sufficient or do I need to drill a hole across and slide a bolt thru?
This is an outside facing wall and load bearing.
jemhunter is offline   Reply With Quote
Old 06-09-2013, 04:29 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Guess ya can't get a full stud in....
Interesting engineering type question.... I would think there are several issues in play.
Obviously the load..... type of wood as to tendency to split which I'm sure there are no specs.... but primarily the length and number of attachements (nails, screws, bolts) of/on the sister.
I would think a very short sister with a bolt might be prone to splitting under certain loads.....
Practically speaking.... I would think in normal residential load, you'd be fine nailing (and clinching over a 31/2 nail), staggering your nailing on the sister, and using as long a sister as possible.
Just my guess though, I'm not an engineer.
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 06-09-2013, 05:26 PM   #3
Rewards Points: 13,242
Why are you having to sister them?
I can see no advantage to through bolting a wall stud.
Old 06-09-2013, 06:16 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
studs are required by the building code to be continuous from sole plate to top plate, no piecing together of studs. if the stud you are going to sister against the other stud is continuous then you can just nail them, after all the shorter stud is doing nothing but taking up space.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
woodworkbykirk (06-09-2013)
Old 06-09-2013, 07:00 PM   #5
Gary....
I think this was the gentlemen who was replacing a piece of rotted mud sill.... and probably obviously did not want to take down his stucco or interior plaster to replace a rotted stud also.
Given that its not code, (and purely from a theoretical discussion as no one is telling him it is code), I generally off the cuff would think that sistering is preferable to blocking underneath that rotted stud.... maybe both would be best???
Just discussing....
Old 06-09-2013, 07:08 PM   #6
kwikfishron's Avatar
Rewards Points: 172
Originally Posted by MTN REMODEL LLC View Post
Gary....
Just discussing....
I'll buy that guess...half of the fun of hanging here isn't just answering questions but it's solving riddles.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
MTN REMODEL LLC (06-09-2013)
Old 06-09-2013, 07:19 PM   #7
DIY staff
Rewards Points: 7,174
It will still be a continuous stud if it is resting on a stack of bottom plates---how high must the cut be?
Old 06-09-2013, 07:26 PM   #8
Good point........ and I really don't remember... maybe only 3-4-5 inches..... apart from code.... what would you do Mike??
Best
Edit: By the way, if I'm remembering correctly, this is Cali earthquake country....
Old 06-09-2013, 07:48 PM   #9
DIY staff
I've never heard of a code limitation on the number of bottom plates--
So that is a good question---I wish I had the answer---
Old 06-09-2013, 07:51 PM   #10
DIY staff
Jem Hunter!!! Howdy, I did not realize it was related to your floor truss thread---
Load bearing section - gap in studs AppleMac*Fit Building & Construction 21 08-09-2012 02:32 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
Replacing Stair Kneewall Studs? jbrukardt Remodeling 7 03-10-2012 10:30 AM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 10:12 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
