Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-06-2011, 11:09 AM   #1
upstairs open room
How to you enclose a half wall on an upstairs room
texas1 is offline   Reply With Quote
Old 01-06-2011, 12:41 PM   #2
Handyman
upstairs open room
You should be able to simply build a frame on top of the half wall up to the ceiling. Make sure you frame with the same size wood as the halfwall to allow for the drywall. Then drywall, mud and tape.
any pics?
canadaclub is offline   Reply With Quote
The Following User Says Thank You to canadaclub For This Useful Post:
texas1 (01-06-2011)
Old 01-06-2011, 05:07 PM   #3
upstairs open room
After you put in the top plate, you need to cut the top plate of the half wall every 4' or so and install a full length stud to stiffen it.
mrgins is offline   Reply With Quote
Old 01-06-2011, 05:36 PM   #4
Handyman
upstairs open room
good point but I would assume the top plate of the half wall is a solid run so attaching to the top plate and a secure fastening to the ceiling should be sturdy enough. Not knowing the structure I am just assuming.
Old 01-06-2011, 05:40 PM   #5
upstairs open room
I'm assuming the half wall has one open end. Even if it doesn't, I think it should be braced so that the is vertical stiffness to avoid cracking of the finish among other things.
Old 01-06-2011, 05:44 PM   #6
Handyman
upstairs open room
mrgins is right..we can only assume...can you provide a picture? Otherwise we are just guessing at this stage
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 02:17 PM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 10:19 AM
On bloody HOT room. rahlquist HVAC 30 04-20-2009 08:50 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
help me solve this mystery please lindaberrien Roofing 17 06-12-2007 02:06 AM
