Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-12-2011, 04:13 PM   #1
Upper Kitchen Cabinets
Any hints/suggestions on supporting upper kitchen cabinets without the availability of a wall to attach the upper cabinets to. I want to basically have an open unobstructed area between the Base cabinets and the Upper cabinets. I'm thinking of installing minimal pillars at several locations, from the floor through the base cabinets on through the upper cabinets. Another method would be to hang down support fixtures/brackets from the ceiling to certain locations of the upper cabinets?
Below are drawings describing the above.
http://tinypic.com/r/2ytzkhi/7
http://tinypic.com/r/15wbayx/7
Last edited by latemoy; 09-12-2011 at 07:21 PM. Reason: posting a picture of the desired kitchen remodel
latemoy is offline   Reply With Quote
Old 09-12-2011, 04:37 PM   #2
m1951mm's Avatar
From the sound of your question will this be on an island going into another room?? And there are base cabinets below?? and no wall?? What is behind the base cabinets?? Will you be working with a corner cabinet at all??
It sure would help if you could post a pic of what you are looking at. That way better ideas on how to support will follow. Will there be LOTS of weight in those upper cabinets??? or is that where the Tupperware will go??
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
latemoy (09-12-2011)
Old 09-12-2011, 04:56 PM   #3
I guess you could do it the way you are describing. You have to make sure that everything is set up in a way to stay tight, because constant opening and closing of doors can throw it off center over time.
It is a shame they don't make anti gravity cabinets, because then you could do it with those.
oldhouseguy is offline   Reply With Quote
The Following User Says Thank You to oldhouseguy For This Useful Post:
Old 09-13-2011, 07:31 AM   #4
As suggested, a pic would help us. There may be not wall, but I assume there is a ceiling. Hang the cabinets from the ceiling.
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 10:45 PM
Kitchen cabinets gmhammes General Discussion 10 11-03-2011 12:43 PM
New Kitchen Cabinets sweaty Building & Construction 0 07-29-2011 09:21 PM
Vintage metal kitchen cabinets WillK Electrical 4 06-02-2011 12:16 AM
Hanging Kitchen Cabinets from soffit...no backwall ronp Carpentry 6 12-15-2008 02:45 PM
