Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-27-2009, 11:48 AM   #1
Default uneven framing for drywall
Hi, This is a beginner's question. Thanks for reading.
I put together a partition wall framing. Now I found that there are some unevenness among the studs and I probably need to so some "shimming?" before I put drywall on.
The unevenness is around 1/8-1/4 inch. Is there any kind of long and thin thing to be put on the framing for filling the gaps?
Thanks again.
hohadcr is offline   Reply With Quote
Old 10-27-2009, 01:01 PM   #2
yummy mummy's Avatar
I had the same problem when I did my first framing job.
What I did, and I don't know if this is what you are suppose to do or if this is what the pros do, but I just nailed another stud beside it, to straighten it out.
Worked for me.
Hope this helps.
yummy mummy is offline   Reply With Quote
Old 10-27-2009, 01:07 PM   #3
http://www.lowes.com/lowes/lkn?actio...0652-157-00100
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-27-2009, 04:11 PM   #4
Thanks.
GBR in WA,
I know there need to be some kind of shims. Do you screw the shims on before drywalling?
This particular shims I have never seen in the HDs in my area. I will ask further. I am up in Canada.
Other than the ready-to-use drywall shims, there is nothing simply to fix the problem?
Old 10-27-2009, 05:11 PM   #5
Find the bowed out stud, cut 3/4 the way through it from the side it needs to move to, attach a plywood gusset (3"x16") to both sides, nail it off when in line. Drive a wood shim in the gap with glue between the cut ends.
Be safe, Gary
Old 10-27-2009, 05:39 PM   #6
Old School
Willie T's Avatar
Be safe, Gary
Here is the sequence up to the point of nailing on the side plywood gussets. I didn't show that because I think we all know how to nail a piece of plywood on the side of a stud.
And the alternative way is to make the same cut from the other side, the convex side.... you'll use no wedge..... then force the stud away from you by toe-nailing the edge of the stud downward and upward (angled) across the cut. (This is if you cannot reach the concave side conveniently.)
uneven-framing-drywall-straighten-studs.jpg   uneven-framing-drywall-straighten-studs-2.jpg
Willie T
Willie T is online now   Reply With Quote
Old 10-29-2009, 07:42 AM   #7
295yards's Avatar
I've never heard of cutting and shimming. Would be cool to try that, I guess. Could imagine it might be a pain.
I reno'd my bathroom and the studs were very uneven. I heard you can use furring strips but could not find them anywhere ( until after ) so I just cut out the crap studs and replaced them.
I've heard alot of people will just splice the junk studs on a 45* and knock them back and sister a new stud.
Whatever works!
295yards is offline   Reply With Quote
More On This Topic
Bob Street with Houdini Home Repair on behalf of Expert Village. We are working on the trellis again today, a little overcast but we are going to deal right with that. What we are going to do is take a nail gun. You saw where we cut the boards earlier... Read More »
So this is where we are going to put the new outlet. I have a stud running down along here or you can find your studs with a stud finder. In an older house a lot of times you can see the nail line running down the wall where they nailed the sheet-rock to... Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will making cleats. Cleats are small pieces of wood that we nail on to our cabinetry that will be on the inside where no one can see it. This will aide when we put our top on will be able... Read More »
How to Frame a Wall
How to Frame a Wall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to frame a wall. When you measure to cut your 2 x 4’s, make sure that you measure your wall and then you subtract 3 inches for your top plate and your sole... Read More »
Shoring Up Exterior Wall Framing Questions Tom5151 Building & Construction 6 09-30-2009 06:55 PM
Framing for drywall under Spiral staircase clemon03 Building & Construction 6 07-17-2009 05:49 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 03:32 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 11:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 06:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
