Uneven Ceiling/wall Line - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 09:52 AM   #1
Uneven ceiling/wall line
Where the wall and the cathedral ceiling meet it is a crooked line. I am looking for a way to at least hide it but from what I am reading crown molding is not the answer. I have attached a picture. Thanks for any ideas.
Uneven ceiling/wall line-wall.jpg
drewfus813 is offline   Reply With Quote
Old 03-17-2013, 09:56 AM   #2
Rewards Points: 196
From the picture it looks like the ceiling hangs down at that spot. Is that the case? Meaning either end of it are the same height from floor to ceiling and it just hangs down at that spot.
Jason34 is offline   Reply With Quote
Old 03-17-2013, 10:13 AM   #3
Rewards Points: 13,250
Your going to have to remove all the sheetrock to fix that one.
That's far more then just a bad tape line.
Old 03-17-2013, 04:23 PM   #4
Drywall contractor
Rewards Points: 1,070
Yeah, that's in the framing. Trim won't fix it. Possible the wall is sagged in that area (probably a long shot). Are you on a basement or crawl space? Maybe jack that area up?? If you're on a slab, you're going to have to do some tear out to see what the issue is.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-17-2013, 10:49 PM   #5
it almost looks like its just painted crooked. there are spots further down the wall it looks crooked also. what about just painting it straight? it would make it a lot less noticable.
Old 03-18-2013, 04:49 AM   #6
Rewards Points: 196
Is it the entire ceiling straight out from there as well or just right there will it meets the wall. How many inches does it hang down there?
Main Line Clog Master Brian Plumbing 46 09-06-2012 09:38 PM
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
