Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-08-2006, 08:34 PM   #1
Under counter microwave replacement
My under counter microwave is dead. I have a new one, but can not figure how to remove the old one. Is this something best left for a pro?
rmh218 is offline   Reply With Quote
Old 11-08-2006, 09:11 PM   #2
747
registered
747's Avatar
I'm not sure could it have slid onto plates under the cabinet. Or are there screws that are assessible from the cabinet above it.
747 is offline   Reply With Quote
Old 11-08-2006, 09:24 PM   #3
World famous jerk.
Under counter, as you say?
or
Under cabinet?
The undercabinet microwaves have two bolts in the floor of the cabinet above.
mdshunk is offline   Reply With Quote
Old 11-08-2006, 09:50 PM   #4
If you are sure you have the correct replacement, then take a look at the installation instructions for that one. If you are lucky, it should be similar to your old one and give an idea of what you need to do.
LanterDan is offline   Reply With Quote
Old 11-09-2006, 11:08 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Different "under-the-cabinet, over-the range" microwave/vent units have different types of brackets.
Normally, they have four bolts. Two long ones the depth of the unit through the front of the microwave that screw into the brackets mounted on the wall behind the unit, and two short bolts through the base of the cabinet above it that screw into the top of theunit itself.
Pop off any vent covers on the front of the microwave to find the bolt screw heads for the long ones. The short ones should be clearly visible in the bottom of the cabinet above the unit.
You will need someone to hold the unit when you start taking those bolts out or it will fall. It's a little difficult to do by yourself.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Corian or Granite counter tops Jms92 General Discussion 21 04-17-2010 07:18 PM
Pass-thru counter gshock Carpentry 6 07-29-2007 12:44 AM
Microwave turning on Central Air!!? Sean F HVAC 7 06-21-2007 09:15 AM
Microwave turning on Central Air!!? Sean F Appliances 1 05-23-2007 11:44 AM
