Uncle Knackers Shows How To Install Base Boards - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 07:22 AM   #1
Uncle Knackers Shows How to Install Base Boards
Hi everyone. Have you ever wanted to know how to cut the perfect internal corner on your base boards.They can be a little tricky. I've knocked up a video to show you how to do just that, and in three easy steps!
Here's the link.
Cheers. Uncle K.
Uncle Knackers is offline   Reply With Quote
The Following User Says Thank You to Uncle Knackers For This Useful Post:
STL B. (06-01-2011)
Old 06-01-2011, 08:58 AM   #2
LeviDIY's Avatar
Rewards Points: 252
Excellent!
LeviDIY is offline   Reply With Quote
Old 06-01-2011, 05:31 PM   #3
Custom Home Builder
Weren't you in Slingblade?
Your coping skills are pretty nasty.
Should be able to cope in continuous run right to the straight cut.
Also, didn't look like you set the mitre saw on a slight angle. Looked like a square cut to me.
I use a jigsaw with a very fine blade.
Cuts nice and clean and much safer.
thomasjmarino is offline   Reply With Quote
Old 06-01-2011, 08:20 PM   #4
Rewards Points: 150
Hmm. I thought after the first cut with the mitre saw that you are supposed to cut the waste back at an angle with the coping saw not make a flat cut. Aren't you supposed to cut it back half?
klmeenan is offline   Reply With Quote
The Following User Says Thank You to klmeenan For This Useful Post:
oh'mike (06-02-2011)
Old 06-01-2011, 11:43 PM   #5
Rewards Points: 150
Yea your videos are much cooler.............Give the guy a break
STL B. is offline   Reply With Quote
Old 06-02-2011, 01:46 AM   #6
bit of a messy cope, but hey looks fine in the end
chrisBC is offline   Reply With Quote
Old 06-02-2011, 01:52 AM   #7
while I agree that we should give applause to someone who takes the time to make a video, his criticism's are actually good advice for someone learning how to cope.
The Following User Says Thank You to chrisBC For This Useful Post:
thomasjmarino (06-02-2011)
Old 06-02-2011, 06:35 AM   #8
NACE Coating Inspector
mustangmike3789's Avatar
thats too funny, i could have made a cleaner cope with toe nail clippers. might be a good ideal to always have your two finished sides facing you too on a miter saw, never against the fence or table since that is where all of the chips will blow out.
mustangmike3789 is offline   Reply With Quote
Old 06-02-2011, 05:33 PM   #9
Rewards Points: 5,336
Crocodile Dundee, eat your heart out.
Ron
Old 06-02-2011, 06:46 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"And there you have it" he says at the end as if he was happy with that mess he just created. If I did a coping cut like that I would use that saw to cut my own throat.
The music is fitting however. Isn't that straight out of DILIVERANCE?
XXX
Old 06-02-2011, 08:37 PM   #11
thats 8 minutes of my life ill never get back , that was the worst i have ever seen , i guess they will let anyone make a how to vidieo now days
fulton 22175 is offline   Reply With Quote
Old 06-02-2011, 08:41 PM   #12
Custom Home Builder
If you want videos, go over to netflix.com.
I prefer craftmanship, that's why I'm here.
Old 06-02-2011, 08:43 PM   #13
Custom Home Builder
Old 06-02-2011, 08:44 PM   #14
Custom Home Builder
Ron
that's funny!!
Old 06-02-2011, 08:46 PM   #15
Custom Home Builder
I think he was in Slingblade
Tags
base board , carpentry , how to fit base board , install base board , skirting boards
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
painting trim and base boards fabian Painting 19 10-10-2010 01:48 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
How to install a preformed shower base Ironman Plumbing 2 01-15-2009 08:36 PM
Carpet installation on Dricore Cyrus Flooring 8 03-24-2008 09:14 AM
