Twisted Support Beam - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 07:25 PM   #1
Hi. Two years ago my husband and I started on a pergola project. We started by putting in 2 8 x 8 x 14 pressure treated posts in - being in Ontario, we had to bury the posts 4 ft in concrete.
We are now wanting to finish it, however, the top of one post has twisted considerably. Is there something we can do to correct this or will we have to pull the post out and start again?
Thanks,
toptopp is offline   Reply With Quote
Old 08-01-2010, 07:28 PM   #2
Civil Engineer
Rewards Points: 4,766
You are not going to untwist the post, however by shaving it down you may be able to get the top straight enough to attach Simpson connectors or similar. Posts which are warped can usually be straightened by applying enough force, but a twisted post, you usually need enough force to break the post to untwist it.
Old 08-01-2010, 07:41 PM   #3
PHB Construction LLC
Paulie's Avatar
I vote for pulling it up and setting a new one. Yes, it's not what you want to hear but it will cause you more problems in the construction later on of the structure. When a lag time between setting the posts and actual construction, it's wise to tack some purlins at the post ends. Purlins are just boards nailed or screwed to the post ends, that connect all the posts. Too be safe fasten them to both sides of the posts and they'll never twist.
Paulie is offline   Reply With Quote
Old 08-01-2010, 10:33 PM   #4
Rewards Points: 1,910
How twisted is it? I'd hate to have to replace a post that big (and set in concrete) unless I really needed to.
Old 08-01-2010, 10:54 PM   #5
Registered User
Rewards Points: 5,514
If you do replace, use a gravel base under the post to let rain water out that it soaked up like a sponge. A post, just like the tree it came from, has connected cells to move and distribute water. Add a wet part above ground and a dry part below (in concrete), along with gravity to get water sitting in the bottom part while the top is air drying. P.t. is not water-proof, unless bought that way: http://www.greenbuildingadvisor.com/...-building-code
http://bct.nrc.umass.edu/index.php/p...ns-about-wood/
Use a granular backfill to help prevent frost heave: http://www.waltersforensic.com/artic.../vol1-no11.htm
Be safe, Gary
Old 08-02-2010, 08:23 AM   #6
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
You an try twisting the footing to square up the post with your framing, although having a significant twist in the post may be unworkable for other reasons. Take a couple 4x4 16-20 feet long (whatever is available) nail them to the post on either side at mid length of the 4x4's a foot or two above the footing. At the end of the 4x4's put a spacer between them and nail the 4x4's to the spacers. Put a couple more spacers a foot out from the post and clamp the 4x4's to them. Run lines form the two ends of the 4x4's to anchor points (tree trunks or something similar) and use come-alongs or a winch to torque the post. Make sure you nail the 4x4's to the 8x8 so that it doesn't slip and make sure you nail the ends of the 4x4's to the spacers (if you don't, the 4x4's will act simply as two 4x4's rather than a built-up section which is much stronger and stiffer). The clamped spacers near the post will keep the 4x4's from trying to separate from the post.
WirelessG is offline   Reply With Quote
Support I beam needed ThisOldH0use Building & Construction 28 05-16-2012 09:10 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 10:14 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 11:03 AM
