TV Recess - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-07-2006, 12:01 AM   #1
Question
TV Recess
HI! I just moved into a home with a TV recess built-in above a fireplace. Problem I have is that my existing TV is approx. 6" deeper than the recess. Short of laying down cash on a new TV does anyone have any suggestions as to how I might be able to accommodate the existing unit? I was thinking about fabricating some sort of tray out of angle Iron so that I could slide the unit in and out for access to the cable connections at the rear and at the same time the tray when fully retracted would remain extended for the 6" or so of added support I need at the front of the unit. Does this make sense and would it be a feasible solution?
Thank you in advance for your consideration!!
Steve is offline   Reply With Quote
Old 06-07-2006, 06:54 AM   #2
Master Craftsman
Big Dave's Avatar
Here is a link to what you are looking for.
http://www.racksandstands.com/asp/sh...B1-PE0062oking
Hope this helps, Dave.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 06-09-2006, 08:50 PM   #3
TV Recess
Many Thanks BIG DAVE! Your response is appreciated!
Steve
why do lights flicker ? amakarevic Electrical 12 05-27-2007 11:24 AM
non-ic recess lighting jvmagic Electrical 6 02-21-2007 04:10 PM
Installing recess lighting spyguy Electrical 14 01-18-2007 08:28 AM
