01-17-2013, 09:44 PM
#1
Turned my riding mower into a lathe!
01-17-2013, 11:13 PM
#2
thats not turning fast enough to be dangerous. unless your a complete idiot, or looking to do harm.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
01-18-2013, 09:36 PM
#3
Well Fix'n, you're at least half right.
Mike Hawkins
01-19-2013, 09:01 AM
#4
yeah, hows that ?
01-19-2013, 09:16 AM
#5
Roofmaster
More time than money huh? Real wood lathes are not that expensive, ya know?
" A lot of men build things, and a lot of things fall down "
01-19-2013, 10:04 AM
#6
Like many other things in life, just because you CAN do it, doesn't mean you SHOULD do it.
01-19-2013, 10:31 PM
#7
yeah, hows that ?
the part about him being a complete idiot.  Actually, I should have said a third right.
Mike Hawkins
01-20-2013, 10:54 AM
#8
Mike Hawkins
ok, how am i wrong ?
01-20-2013, 02:31 PM
#9
Just a goofball looking for attention. I'd ignore him. Other than holding a chisel on top of a cinder block by hand, it's not that dangerous - more like just attention seeking.
01-20-2013, 02:45 PM
#10
I didn't mean it as you were wrong at all. I was agreeing with you. I actually think you were 100% right.
Mike Hawkins
01-30-2013, 01:52 AM
#11
I did almost the same thing with a 91 Ford car the nieghbor gave me. Except I welded two rims together and put it back on and locked up the other front tire so I would get full power from that wheel and then I ran the lathe with a belt off the extra rim. Now I have an actual wood lathe... works much better.....
01-30-2013, 02:31 AM
#12
JOATMON
Considering that on most mowers like that you can disconnect the blades....not sure what the danger is......
I think jeffnc has it nailed.......hence, I'm not impressed.
Can I have those 2 minutes back?
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
