-   -   Tub Deck Framing (http://www.diychatroom.com/f14/tub-deck-framing-29953/)
FlyBoyd 10-14-2008 06:24 PM
Tub Deck Framing
Hello all...first post on a new project.
I am in the process of remodeling my master bath and have a question. When framing a tub deck, what are my options for attaching it to the slab? The actual dimensions, studs 16" on center doubled on the corners, and attaching to the walls I've got a grip on...any suggestions on how to secure it to the floor (slab)?
Thanks,
Boyd
buletbob 10-14-2008 07:02 PM
first make sure you know where the heat lines,hot & cold water lines are located if under the slab, lay out your platform on the floor and then install a single 2x4 ACQ on the slab, install with either Tapcon's or masonry nails what ever is available to you. and work up from there. I install a sheet of 3/4 plywood on top of my finished framing mark my tub template and cut out with a jig saw. then I finish off with a sheet of 1/2" duro rock. So the bottom line is to find the exact height from the floor to the underside of the tub platform flange. then deduct your plywood, duro-rock, and tile/granite/marble.what ever you choose for your surface material.You should be good to go, And don't forget the access panel
GOOD LUCK BOB I love useing the split drive'shttp://www.concretefasteners.com/ima...ive-anchor.gif
zack 10-17-2008 11:50 PM
Class
Thanks,
Boyd
Hi Boyd,
The best thing to do is 1/4'' by 3 1/2'' wedge anchor drill 1/4 hole through plate into concrete (roto hammer) pound wedge in or concrete nails if your lucky.
chalk_hill 10-18-2008 11:32 PM
I apply plenty of caulk or liquid nails to the bottom plate and tag it with a couple of shot-pins to keep it located while the adhesive sets.
Wedge-anchors etc, are a bit overkill IMO me since there is never any uplift on a tub deck, and usually, by the time all is said and done a tub surround is fairly overbuilt with multiple bracing layers.
