Trying To Get Screws To Hold In Soft Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-22-2007, 09:17 PM   #1
Trying to get screws to hold in soft wood
Hi;
I am hanging a bi-fold door. I have it all done, except that one of the screws holding a bracket to the door will not hold because the wood is too sot.
I have already tried a plastic anchor to no avail.
A larger screw didn't do the job either.
At this point, I know that the only thing that will work is a molly type bolt.
I need something small enough to go into a 3/8 hole and accept a #10 - 12 screw.
This cannot be the familiar wing type molly bolt, as I need it to go into a piece of wood that is only about 3/4 square.
Another possibility is inserting some sort of bolt into the frame of the door from the edge, then allowing a long screw or threaded rod to screw into it.
Whatever it is, I need something for the screw holding the hanging bracket to hold onto so it won't pull out.
FW
fw2007 is offline   Reply With Quote
Old 08-22-2007, 09:20 PM   #2
Remodeler
MinConst's Avatar
Drill out the hole to accept a 3/8" dowel. Glue the dowel in the hole and drill for a screw. Make sure the dowel hole is correct size and the glue is good and dry (overnight).
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 12:24 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
