Trying To Decide - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-21-2011, 09:22 AM   #1
Unhappy
Trying to decide
I bought our house a couple years ago, and have found several issues with the basement finishing the previous owners did. I have found that all the tape lines are visible on the drywall, the moulding is not straight or nailed, doors hung crooked, and several other issues. I am considering starting over even though it is finished. With this many problems, do you think I should go back to the studs and see what else he did wrong?
Don't have any pictures here at work, but just some other side notes. Some of the exposed studs in the closets are severly warped, some of the walls are not attached to the concrete floor, you can feel drafts coming from the walls, and some of the wiring is suspect. I am also changing the lighting from track to recessed, getting rid of the popcorn cieling and putting in a built in for the TV with bookcases.
MilitaryGuy1982 is offline   Reply With Quote
Old 11-21-2011, 09:31 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope! Generally the drywall seams can be repaired. How about a few pictures?
Doors can be re-hung.
Old 11-21-2011, 11:36 AM   #3
A Little Of Everything
Rewards Points: 1,364
Bud is right. Don't rip it all out - at least not yet, anyway. Shoddy finish work can sometimes be corrected, and rather easily. That popcorn ceiling texture crap can be moistened and easily removed. Recessed lighting is not overly difficult to install. You might just have a bunch of tweaking that needs to be done.
On the other hand, if the previous owner didn't insulate (and probably didn't use vapor barrier either), used bad materials, and wired everything incorrectly, you might be better of just ripping it down & starting over.
DrHicks is offline   Reply With Quote
Old 11-21-2011, 04:11 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
you dont have to tear everything out, i would remove the drywall only where the draft is. dont worry about the partitions.. you can skim coat the bade mud job on those walls. the bad trim and doors definitely should be taken care of
woodworkbykirk is offline   Reply With Quote
Old 11-21-2011, 04:28 PM   #5
Registered User
Rewards Points: 5,516
"you can feel drafts coming from the walls," ------ open an inspection hole in the area and check for rigid foam board on the concrete.
Where are you located?
Gary
Old 11-21-2011, 05:08 PM   #6
Rewards Points: 5,336
I'd explore the electrical and the insulation.
Ron
B. Franklin 1759
Old 11-22-2011, 08:16 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
My experience has been that if the exposed work is shoddy, then what's behind it is no better. You can fix trim and bad drywall finish, but in the end you may be putting lipstick on a pig. You have loose walls, drafts and suspect wiring. I'd get rid of it and do it right.
help me decide where to make my shop! Red Squirrel Off Topic 16 01-07-2011 08:14 PM
help me decide on a shed foundation please Cruzomatic Building & Construction 1 06-28-2010 09:38 PM
Can't Decide Wirsbo or SS Clamp Style PEX? twilightcall Plumbing 1 02-09-2008 09:11 AM
need information to decide hyyx632 HVAC 7 05-01-2007 12:09 PM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 08:23 AM
