-   -   Trying to decide (http://www.diychatroom.com/f14/trying-decide-124161/)
MilitaryGuy1982 11-21-2011 09:22 AM
Trying to decide
I bought our house a couple years ago, and have found several issues with the basement finishing the previous owners did. I have found that all the tape lines are visible on the drywall, the moulding is not straight or nailed, doors hung crooked, and several other issues. I am considering starting over even though it is finished. With this many problems, do you think I should go back to the studs and see what else he did wrong?
Don't have any pictures here at work, but just some other side notes. Some of the exposed studs in the closets are severly warped, some of the walls are not attached to the concrete floor, you can feel drafts coming from the walls, and some of the wiring is suspect. I am also changing the lighting from track to recessed, getting rid of the popcorn cieling and putting in a built in for the TV with bookcases.
Bud Cline 11-21-2011 09:31 AM
Nope! Generally the drywall seams can be repaired. How about a few pictures?:)
Doors can be re-hung.
DrHicks 11-21-2011 11:36 AM
Bud is right. Don't rip it all out - at least not yet, anyway. Shoddy finish work can sometimes be corrected, and rather easily. That popcorn ceiling texture crap can be moistened and easily removed. Recessed lighting is not overly difficult to install. You might just have a bunch of tweaking that needs to be done.
On the other hand, if the previous owner didn't insulate (and probably didn't use vapor barrier either), used bad materials, and wired everything incorrectly, you might be better of just ripping it down & starting over.
woodworkbykirk 11-21-2011 04:11 PM
you dont have to tear everything out, i would remove the drywall only where the draft is. dont worry about the partitions.. you can skim coat the bade mud job on those walls. the bad trim and doors definitely should be taken care of
Gary in WA 11-21-2011 04:28 PM
"you can feel drafts coming from the walls," ------ open an inspection hole in the area and check for rigid foam board on the concrete.
Where are you located?
Gary
Ron6519 11-21-2011 05:08 PM
I'd explore the electrical and the insulation.
Maintenance 6 11-22-2011 08:16 AM
My experience has been that if the exposed work is shoddy, then what's behind it is no better. You can fix trim and bad drywall finish, but in the end you may be putting lipstick on a pig. You have loose walls, drafts and suspect wiring. I'd get rid of it and do it right.
