Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-20-2004, 11:23 PM   #1
trusses
I'm building a house and need to know how to set roof trusses manually. Can anyone help me?
M.Plummer is offline   Reply With Quote
Old 11-20-2004, 11:26 PM   #2
trusses
If you are referring to how to set them on the roof by hand I would suggest that you cheat and rent an all terrane forklift.
Daniel O'Connor is offline   Reply With Quote
Old 11-30-2004, 08:57 AM   #3
trusses
I'm not sure what help you need, can you be alittle more specific about what you do or don't know or understand???!!! When I first started in construction we always set trusses by hand!! It's pretty straight forward, just use common sense!! But let fly what questions you have and like I said, be alittle more specific!! Good Luck!!!!!!!!
Dave
steg32168 is offline   Reply With Quote
Old 07-03-2005, 03:28 PM   #4
trusses
I would be interested in reading more about this if anyone has time to chime in.
meiersenterprises is offline   Reply With Quote
Old 07-03-2005, 11:08 PM   #5
Contractor
trusses
Dave, you must be another oldtimer. I remember buggylugging trusses by hand, took quite a few guys and is one of the other reasons that my back is bad. LOL
We used to snap the line off center so that it lined up with the edge of the crosstie, better than trying to guess the center. We roughed in the peaks, set them with temp 2X4's until it was sheathing time.
Teetorbilt is offline   Reply With Quote
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 08:36 AM
Pitched roof with trusses over tar and gravel shane.nesbitt Roofing 6 06-02-2007 12:03 PM
Joists - TGI vs. Web Trusses handy man88 Building & Construction 3 04-02-2007 12:34 PM
Reinforcing Ceiling Trusses powrus Building & Construction 2 02-24-2007 09:10 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 04:48 PM
