Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-05-2011, 06:47 PM   #1
Trussed rafters w/ cut truss chords
Trussed rafter type roof. I feel dumb asking, but I thought one was not supposed to cut the trusses. Am I mistaken and these are not truss chords?
Trussed rafters w/ cut truss chords-dsc014511.jpg
sacseven is offline   Reply With Quote
Old 10-05-2011, 06:50 PM   #2
the Musigician
DangerMouse's Avatar
No, you should not cut them. Are you asking or saying someone cut some that you know about?
I'm a bit confused by your question?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 10-05-2011, 07:08 PM   #3
Mod
kwikfishron's Avatar
I don’t see any trusses.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 10-05-2011, 07:34 PM   #4
the Musigician
I only saw the drawing last time I was here. hmmmmmmm
DM
Old 10-06-2011, 07:11 PM   #5
Something has been cut, I guess I would like to know if it appears to be structural?
Old 10-06-2011, 08:06 PM   #6
Mod
I see random length ceiling joist sitting on a wall and the adjacent room with a lower ceiling. It doesn’t look like anything structural was cut (to me anyway). It looks like it’s always been that way.
-NEW MEMBERS-
The Following User Says Thank You to kwikfishron For This Useful Post:
DangerMouse (10-07-2011)
Old 10-08-2011, 12:07 AM   #7
I would agree with you! The butts that are circled in the photo are the ends of the raised ceiling joists.
if I were framing this, I would have placed a rim joist here, to prevent the joists from twisting, as they dry.
Old 10-08-2011, 12:29 AM   #8
Moderator
You have rafters and ceiling joists, not trusses. The diagonal bracing are struts, holding up the purlins, Figs. 8 and 9: http://docs.google.com/viewer?a=v&q=...RMyCq7zQ737mAg
Gary
Clothes taking longer to dry?
Old 10-08-2011, 06:00 PM   #9
You have a stick-framed roof. The "missing" ceiling joists are important in my opinion as they help resist the downward and outward effects of roof thrust when the two main exterior walls aren't continuously tied together via the ceiling joists. If you have a dropped ceiling (like a utility room) between the main rooms, then you're asking the part of the studs above that height to help shoulder resistance load against roof spread. I'd nail a few 2x8's to the ends of the 'cut' joists and bridge that gap to create a continuous plate line link. Roofs spread loads downward and the exterior walls bear the brunt of this force. You're absolutely right to say 'something doesn't look right here.' Doesn't look right to me either. Also won't cost you much to remedy yourself as solid insurance against a future problem. The link below from an engineer shows pics that demonstrate roof thrust failure.
http://www.unified-eng.com/ch/thrust.html
$49 Handyman is offline   Reply With Quote
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
Roof bracing / pulling rafters together JoeT Building & Construction 8 07-08-2010 08:54 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 01:08 PM
Attaching Rafters to existing roof truss' houstonbrama Building & Construction 7 08-21-2008 02:39 AM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 08:36 PM
