Truss To "I" Beam - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 11:37 AM   #1
Truss to "I" beam
I am building a room on to my home. I have an "I" (6x15) steel beam which one end of my truss will be sitting on? I know I will have to strap them down but how do I attach them to the beam? OR do they just sit on the beam and the straps hold them on?
mikeyz43 is offline   Reply With Quote
Old 05-23-2011, 02:09 PM   #2
Tizzer's Avatar
Rewards Points: 460
Ugh?
Tizzer is offline   Reply With Quote
Old 05-23-2011, 02:32 PM   #3
Rewards Points: 5,336
I'd install the steel 1 1/2" below the truss level and cap it with a 2x6. Nail the trusses into the wood.
Ron
Old 05-23-2011, 05:20 PM   #4
Framing Contractor
Ask the Architect who drew the plans. If you don't have that. Ask your building inspector how to do it. Do you have plans and permits?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-23-2011, 05:33 PM   #5
Framing Contractor
Rewards Points: 120
That is one wimpy beam. I hope it only spans about ten feet.
sixeightten is offline   Reply With Quote
Old 05-30-2011, 10:03 AM   #6
Span
Its spanning 30'. It weighs enough, took two of us all day to get it up 8 foot, by hand(jacks). It will be sitting on 4 - 3"square post space about 10' apart.
Old 05-30-2011, 10:05 AM   #7
Yea a set of $3500 plans and permits that cost us $500.00 and haven't even started.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
