Trouble With Stair Stringers - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 11:51 PM   #16
I love all the suggestions!
Ok so should the posts...newel handrail posts be bigger than the hand rails?
Reason why I am asking is my friend helping says just use a 4x4 doug fir for the posts as well as the handrails
I personally think I want the posts to be BIGGER! If you look at the photo, the posts are 4x6 or 4x8...just my opinion!
BTW Im paying for this so my opinion is the one that counts!
What are your thoughts?
chulett is offline   Reply With Quote
Old 02-27-2011, 09:52 AM   #17
Stairguy
Millertyme's Avatar
Rewards Points: 508
there are strict building codes when it comes to handrail. Handrails are not to exceed 2-5/8" in width where I am from. They also must have at least 1/4" radiused corners for square rails. Check your local code. A 3-1/2" wide handrail is useless in my opinion.Way too big.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
BigJim (02-27-2011)
Old 02-27-2011, 03:45 PM   #18
The rails in the photos don't show a 3 1/2" handrail
mrgins is offline   Reply With Quote
Old 02-27-2011, 10:32 PM   #19
would use the 4x4 doug fir for the hand rails because they are handy...I had no idea they could not be that large..why is that?
Old 02-28-2011, 04:27 PM   #20
Code says it has to be easily grippable
The Following User Says Thank You to mrgins For This Useful Post:
BigJim (02-28-2011)
Drywall bottom of stair stringers question hewey24 Drywall & Plaster 2 11-10-2010 05:24 PM
Stair building - Traditional stringers or EZ Stairs? dwoloz Carpentry 12 08-24-2010 10:26 AM
Stair Stringers mntnvew Carpentry 14 04-14-2009 01:09 PM
Fastening stair stringers bacdef Carpentry 6 08-07-2008 10:31 PM
Installing floating engineered hardwood in entrance and stair stringers bluedisc22 Flooring 3 01-25-2008 03:03 PM
