Trouble Removing Sliding Glass Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-02-2006, 06:23 PM   #1
I need to temporarily remove my sliding glass door to move furniture. The screen lifts up and pops right out. But it only has one actual door, the other side doesn't open or close. I need both panes of glass removed.
There is a "column" piece in the middle, which connects to the immovable side. There were two screws in the column, one at the top and one at the bottom. I removed the screws and I still can't get the column to move at all. Also, I can't pop the sliding door out without removing the immovable pane first.
Any information at all would be greatly appreciated!!
Drewimus is offline   Reply With Quote
Old 11-05-2006, 12:43 AM   #2
Log-Style Home Contractor
North Country's Avatar
There should be removable plugs that cap the screw holes on the inside bottom, (one each side) and on the top and inside edge. They are buggers.
North Country is offline   Reply With Quote
sliding glass door security... sflamedic General DIY Discussions 5 07-31-2009 01:00 PM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 08:49 PM
Sliding Glass Doors Drewimus General DIY Discussions 2 10-02-2006 09:06 PM
Help!! Removing sliding doors? luo2000 General DIY Discussions 11 04-10-2006 11:10 AM
removing frame to sliding glass door luo2000 General DIY Discussions 1 04-09-2006 08:00 PM
