Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-09-2010, 08:17 PM   #1
artlover13060's Avatar
trimming UNDER a staircase
I am building a mini dry bar under the staircase in my basement. The area above the counter will be covered with bead board paneling. Since this is under the stairs, the ceiling is sloped. I plan to cover the sloped part of the ceiling with beadboard also. What kind of trim should I use where the back wall and the sloped ceiling meet? What kind of trim along the sloped ceiling and side wall?
artlover13060 is offline   Reply With Quote
Old 08-09-2010, 08:43 PM   #2
Stairguy
3/4" square stock in the corners
Millertyme is offline   Reply With Quote
Trimming a staircase Richo Carpentry 38 09-30-2010 10:13 AM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 02:55 PM
