Trimming Out Quarter Round Replacement Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 10:36 PM   #1
Trimming out quarter round replacement window
I just recently replaced some windows and 2 of them are quarter round, 30" high, 30" wide. I've trimmed out the normal windows with masonite for the jambs and just the usual window casing, just not sure how to go about getting a quarter round to look the same or similar.
Any suggestions?
Thanks.
Drew
Trimming out quarter round replacement window-arched-window.jpg   Trimming out quarter round replacement window-finished-window1.jpg
OKDrew63 is offline   Reply With Quote
Old 07-05-2012, 10:41 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can order the trim from the window manufacture usually
or you can use flexible trim
http://www.trimster.com/flextrim.asp...FcXe4AodvXFkFA
Tom Struble is offline   Reply With Quote
Old 07-05-2012, 10:47 PM   #3
Rewards Points: 12,830
Your also going to have to build jamb extentions.
With all the stuff going on at the very tops of the windows you may be stuck with sheetrock returns and no trim. The narrowest colonial moulding is 2-1/4 and it looks line there's no room for it at the peak.
2, layers of 1/4 sheetrock sprayed with water on the back side will flex enough to make the curve and they make sheetrock moulding with notches in it for making curves like that.
Old 07-06-2012, 09:47 AM   #4
Home Remodeler
Rewards Points: 164
I agree, break out the mud and sheetrock. I might try osing half inch and cut grooves on the back for the curves.
mikey48 is offline   Reply With Quote
Old 07-07-2012, 07:56 AM   #5
That's how my windows were previously trimmed out, drywall all the way around for the jambs, except for the bottom. I have 2, 6' windows directly below these quarter rounds, would you think having 2 sets of windows finished differently so close together look okay? Do I have much choice?
Thanks.
Old 07-07-2012, 10:00 AM   #6
A rock return would sure look better then having the top all cut up to clear whatever that is at the top.
mae-ling (07-07-2012)
Old 07-07-2012, 10:57 AM   #7
Rewards Points: 2,202
Normally I'd say match the rest of the trim, but I agree with Joe.
mae-ling is offline   Reply With Quote
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
Window replacement procedures Mudball Building & Construction 3 02-21-2010 09:36 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
