Trimming Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 07:03 AM   #1
Rewards Points: 101
Trimming Molding
In the house I just purchased there is an a.c. mounted in the wall that has been framed by molding. The outlet would have been covered by the molding so it looks like it was trimmed prior to being mounted. However it was not trimmed enough and it seems they never bothered putting an outlet cover plate on.
I'd like to get the plate on and was wondering what tool might be best for trimming about another half inch or so off the molding above the outlet and next to it? I wanted to do this without having to take the molding off.
jte1130 is offline   Reply With Quote
Old 01-28-2008, 07:33 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
About the only tool that can do such is....drum role please:
THE FEIN MULTI-MASTER!!: http://www.kk.org/cooltools/archives/001109.php
A little pricey tho, for the average DIYer.
The only alternative is to:
a.) Remove the molding, cut and re-install.
b.) Leaving the molding on the wall: Use a utility knife to score the cuts. Take a very sharp chisel, and go to town. Unfortunately, you are going to make a mess of the molding and possibly crack the drywall.
The proper method is to remove the molding and make your cuts. Personally, I'd buy a matching section of molding, do the cuts, and install after removing the old one.
Good luck!!
- Build Well -
Old 01-29-2008, 08:20 AM   #3
Atlantic is right.. Best way is to remove the molding and make your cuts.. Why dont you just cut the cover plate instead?
RTRCon is offline   Reply With Quote
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
Wainscot molding issues cmdrico7812 Remodeling 2 02-01-2008 12:54 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 10:12 PM
Installing Crown Molding fmolden Carpentry 6 01-08-2008 10:09 AM
Baseboard molding tiled in... Donald Lynskey General DIY Discussions 1 07-07-2007 06:47 PM
