Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-06-2012, 11:48 PM   #1
ltd
trimming masonite 6 panel doors
whats the best way to trim 3/8 inch off sides of door and 1/4 inch off bottem? with out messing up the doors finish .im thinking power planer ,mabey hand planer ,or just a skillsaw with a clamped down fence .anybody work with these door lately?
ltd is offline   Reply With Quote
Old 12-06-2012, 11:49 PM   #2
Tape the cuts to limit splintering. Have a table saw or track saw?
mbryan is offline   Reply With Quote
The Following User Says Thank You to mbryan For This Useful Post:
ltd (12-08-2012)
Old 12-08-2012, 08:12 AM   #3
Freud thin blade with 40 teeth or more gave me good results. You can cut close to pencil line and finish with a plane or belt sander.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
ltd (12-08-2012)
Old 12-08-2012, 08:16 AM   #4
Is that 3/8 on each side or 3/8 in total?
oh'mike (12-08-2012)
Old 12-08-2012, 08:59 AM   #5
Super Moderator
Check the bottom of the door and see how much thickness the edges have---some of the cheap ones only have 1/2" or so ---removing that much may destroy the door---
If the door is drilled for a lock set--all trimming must be done from the hinge side or the lock set back will be wrong and the door will be ruined---Use a slab door and bore your lock holes after any trimming--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ltd (12-08-2012), woodworkbykirk (12-08-2012)
Old 12-08-2012, 09:05 AM   #6
That's what I was thinking.
As cheap as those doors are I'd concider just installing a whole new prehung.
Old 12-08-2012, 01:56 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
or use a solid core.. no worrying about putting the filler strip back in or the door falling apart over time because the glue joint fails
woodworkbykirk is offline   Reply With Quote
doing something to masonite doors tkh1957 Interior Decorating 2 08-15-2012 10:10 AM
Tips on painting 6 panel hollow core doors speedster1 Painting 28 06-19-2012 01:51 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
flat doors to 6 panel? Yeti Remodeling 8 03-05-2008 01:18 PM
