Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-11-2008, 09:29 PM   #1
Do it yourselfer
Default Trimming Fiberglass doors
My husband and father-n-law installed a fiberglass storm door in the entrance to our home. Everything worked out good except for the fact that the door is about 2-3 inches too long and now that it's installed it takes some force to open and close the door. I won't have too much of a problem but we intend on installing real hardwood floors in the near future and as long as we have this door the hardwood floors will prevent the door from opening. Can we have this door trimmed off on the bottom? And if so how?
Stephanie
sjaconski is offline   Reply With Quote
Old 10-11-2008, 11:43 PM   #2
Stephanie,
The mental picture your description paints is a little confusing to me.
Most storm doors are installed on the exterior of the jamb and swing out.
"Real hardwood floors" are typically installed in the interior of a home.
The door is installed ,but "2-3 inches too long".
Can you post a few digital photos?
Big Bob is offline   Reply With Quote
Old 10-12-2008, 10:30 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I agree pictures would be helpful, along with more a more detailed description of the issue.
- Build Well -
Old 10-13-2008, 11:36 AM   #4
Do it yourselfer
I'm sorry it is the interior front door which is a six panel fiberglass door. It swings inword. I got that door confused with the storm or screen door. There is no breathing room in between the foyer foor and the bottom of the door where the rubber strip is.
Old 10-13-2008, 08:14 PM   #5
A "Handy Husband"
Trimming the door is not an option. The door needs to be totally removed, including the frame. The door and frame needs to be raised in the rough opening high enough to clear the new flooring. This may (and most probably) mean you have to remove and raise the header that frames the rough opening. Not a job for the faint of heart.
rjniles is offline   Reply With Quote
Old 10-14-2008, 10:12 AM   #6
Do it yourselfer
The frame of the door is surrounded by one by fours so we can't get any smaller than that. But my father-n-law did mention raising the door and frame. He didn't sound so excited about it so I'm assuming it's a difficult job? Do you think it's worth the hassale? My only other option would be to have a new door special ordered which would mean I just wasted about $250.00 on this standard door plus the cost of a special ordered door which I heard is not cheap.
Old 10-14-2008, 10:38 AM   #7
A "Handy Husband"
If it was my house I would raise the door even if this means raising the header. I think it would be cheaper than buying a custom door and wasting the $250 you have already spent.
Check to see how much highth you have with you existing rough opening. Remove the inside trim above the door. If you have 3/4 inch or more above the door frame to the header you should be able to raise the door without redoing the header. If not (see below):
Short course (assuming raising header):
Remove door and frame. Remove dry wall to ceiling. Remove header, jack studs and cripple studs. Determine header highth required and cut jack studs to that length. Reinstall header, jacks and cripples. You will probably have to cut back the exterior sheathing and deal with any siding issues. Re-drywall and finish. Install filler strip under door the highth of your new finished floor. Reinstall door.
Old 10-14-2008, 02:59 PM   #8
Do it yourselfer
Thank you so much for all your help. Wish us luck
More On This Topic
How to Remove a Car Tire
How to Remove a Car Tire by Expert Village
Hey I'm Jake from Burt Brother Tire and on behalf of expertvillage.com, we're going to show you how to, once we've raised the tire off the vehicle, off the ground with the jack, we've loosened the lug nuts, I'm going to show you how to continue to remove... Read More »
Changing tire is a useful task for everyone to learn. This skill should be practiced often to reach optimum comfort in changing a tire. The steps that follow are based on changing a tire on a Ford Expedition. Read More »
In this clip, we're going to talk about the proper service procedure in order to remove and replace a broken CV joint also known as a drive shaft on a front-wheel drive vehicle. In this step, we're going to talk about the proper service method for... Read More »
Everyone should know how to change a tire on his or her vehicle. These skills should be practiced often to reach optimum comfort in changing a tire. The steps that follow are based on changing a tire on an Expedition. Read More »
Working on Side Brake Lines
Working on Side Brake Lines by Expert Village
In this clip we're going to talk about the proper service procedure to inspect, remove, and replace your steel brake lines and bleed the braking system on a Ford Explorer. In this step we're going to talk about the proper jacking procedure for raising... Read More »
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 09:47 PM
painting fiberglass doors rcahow Painting 2 07-11-2008 07:21 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 07:04 PM
Fiberglass French Doors w/built-in blinds Ventana Building & Construction 0 05-11-2008 11:05 PM
Trimming Bi-fold doors Designman20 Carpentry 2 05-15-2007 11:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
