Trimming The Bottom Of Baseboard Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 05:34 AM   #1
CitadelBlue's Avatar
Rewards Points: 97
Trimming the bottom of baseboard molding
I’m beginning prep work for my hardwood floor install and I’ve discovered that the space between my subfloor and base molding isn’t large enough to slip the hardwood under the baseboard molding. I’d like to be able to slide my new hardwood floor UNDER my existing baseboard molding. Years ago I watched a flooring guy use a “self modified” circular saw without the guards on to cut the bottoms off from around doorways. Basically, he rested the bolt that held on the blade on the floor and cut away.
I would use my trusty Japanese saw, but there isn’t enough room to push and pull it under the baseboard to cut off that ¼ inch or so and I really didn't want to modify my one and only circular saw.
I'd rather NOT removing the baseboard molding (1x4 plus ogee molding). Does anyone have any ‘safe’ ideas or a solution (short of doing nothing)?
CitadelBlue is offline   Reply With Quote
Old 05-27-2013, 05:48 AM   #2
kwikfishron's Avatar
Rewards Points: 998
Either remove the base or leave it and add a shoe molding.
Even if you tried to cut the base in place it would be difficult to get a finish quality cut everywhere and you would likely end up adding another piece of trim there anyway.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
RWolff (05-27-2013)
Old 05-27-2013, 06:22 AM   #3
Rewards Points: 97
Thought about that, but I'd still like to trim off the baseboard ....
Old 05-27-2013, 06:36 AM   #4
DIY staff
Rewards Points: 7,174
Rent or buy a Crain jamb saw---these are designed for undercutting---
Harbor Freight makes one also---
Buy extra blades---as to safe---no no no --that is possibly the most deadly dangerous wood cutting tool ever invented.
How much molding? I always pull off the base ---
Old 05-27-2013, 06:41 AM   #5
Rewards Points: 97
Yep ....got about 80 feet of molding to trim. Was trying to save some time (and $$) by not having to remove the molding.
You are correct looks like a long neck jamb saw
http://www.amazon.com/s/ref=nb_sb_no...g=vglnk-c47-20
or a toe kick saw might work too....... http://www.harborfreight.com/3-3-8-e...saw-94626.html
is what I need …….
Old 05-27-2013, 08:07 AM   #6
Old School
Willie T's Avatar
Not a good idea. Seriously.
Even after you cut off the bottom of the base, there will be many, many areas where the flooring still won't go under the way you want it to, and also areas where the baseboard will leave too much of a gap showing after the flooring goes in. Either way, you'll be resorting to shoe molding to hide these things. Just go ahead and use it now.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
oh'mike (05-27-2013)
Old 05-27-2013, 09:09 AM   #7
Framing Contractor
Rewards Points: 126
Either remove the base and reinstall, or use the shoe. Since you will be moving it up, you will be able to hide the paint line. Removing 80' of base carefully should only take a few minutes. The reinstall is probably about an hour. The final results will be noticeably better.
sixeightten is offline   Reply With Quote
The Following 2 Users Say Thank You to sixeightten For This Useful Post:
oh'mike (05-27-2013), Willie T (05-27-2013)
Old 05-27-2013, 06:16 PM   #8
Rewards Points: 2,648
.... that room sure would look good with a new floor AND new oak baseboard molding.
SPS-1 is offline   Reply With Quote
Old 05-27-2013, 06:23 PM   #9
Old School
Willie T's Avatar
But it would also need new oak casing first.
Willie T
Old 05-27-2013, 07:07 PM   #10
funfool's Avatar
Rewards Points: 534
I dunno, maybe I missed something.
I just do not understand what the real issue is, You are going to do real hardwood install and not remove the baseboard?
Who is doing this hardwood install, lets ask them.
The trim is the least of your issues and is something you put back when the floor is finished.
If you cant run baseboard, I would not want to see your hardwood floor you install.
Really, no harm meant, just a weird question for a floor installer.
Yank the baseboard and do it right!
funfool is offline   Reply With Quote
Old 05-27-2013, 07:55 PM   #11
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
The normal way is just pull the baseboard off, lay the floor and put the baseboard back on, either higher or trimming the bottom, it's no big deal they are just nailed in.
The other way, as someone sugegsted, you can nail on a 1/4 round molding I guess.
Sculpture scholarship recipient, 2008
Asbestos information: http://www.diychatroom.com/f98/asbes...pt-1-a-181840/
RWolff is offline   Reply With Quote
Old 05-29-2013, 02:26 PM   #12
Roofmaster
Rewards Points: 2,210
Shoe Molding! Why are you-all making this harder than it needs to be ????
Old 05-29-2013, 03:13 PM   #13
Old School
Willie T's Avatar
"You all"? I'm pretty sure I wrote post #6.
Willie T
mae-ling (05-29-2013)
Old 05-29-2013, 04:46 PM   #14
Rewards Points: 2,212
My understanding is because the original poster does not want it.
Pull off base and reinstall is the next way to do it
mae-ling is offline   Reply With Quote
Old 05-31-2013, 06:52 AM   #15
While I agree that removing the baseboard would be my preference, if one were opposed to this for some reason, an oscillating saw does a nice job of undercutting. If you can locate one of those Makita undercut saws, those work even better. Alternatively, I see specialty offset blades for installation into reciprocating saws intended for this undercutting purpose.
oberkc is offline   Reply With Quote
Electric Baseboard Convection Heater - Buying House Info? olimits7 HVAC 4 10-24-2012 09:45 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 08:32 AM
Caulking bottom of baseboard? maximizer Painting 15 12-09-2006 02:07 AM
