Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-11-2007, 10:04 PM   #1
Trimming Bi-fold doors
i have a rough opening of 23" wide x 80" high. Instead of buying custom bi-fold doors i purchased 24" wide doors. my strategy is to trim each leaf (on the hinge side) a little more than a 1/4" so that it would fit. The doors are mahongany with louvers and the jambs are 1-1/2" wide, since the louvers are set in the jambs would i be ok if i took that 1/4" off? will i make a mess when i run it thu the table saw and hit all the louvered slats? i'm assuming that the jambs are of solid stock.....
any advice?
thanks!!!!!!!
Designman20 is offline   Reply With Quote
Old 05-11-2007, 10:15 PM   #2
fhi vinyl windows
fhivinylwindows's Avatar
where to get custom bi-fold doors check out this thread.
aaa
fhivinylwindows is offline   Reply With Quote
Old 05-15-2007, 10:12 PM   #3
remodeling pro
When you say a "rough" opening , I assume you really mean the clear opening of the jambs? This is going to be pretty close in my opinion, because you are actually going to need to take more than 1/4" off or the outside corners of the doors will bind when they pivot. They cannot be fitted that tight in the jambs. Whether you can take 5/16" off without exposing the ends of the louvers just depends on the manufacture of the doors. My guess is that the louvers are not mortised that deep and will be OK, but it's just that, a guess. Also taking all the cut on just the hinge side is going to make it pretty easy to see the different widths of the stiles, you would be better to trim both sides of each panel. Good luck.
troubleseeker is offline   Reply With Quote
More On This Topic
Detailing your vehicle is an important step to maintaining the car's condition and value. If corrosion, residue and other gunk is allowed to build up on the working components of your vehicle, they can lead to malfunctions in the parts. This is true for... Read More »
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Now we're going to talk a little bit about spackling on a door jamb. Now, earlier we talked about spackling walls. Now interior or exterior walls... Read More »
How to Caulk Trim
How to Caulk Trim by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Okay now we're going to talk a little bit about caulking interior door jambs. Now, this is very different from anything else you caulk, Now this is... Read More »
Watch conclusion for refinishing a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn how to paint refinished door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
outswing patio doors philS Building & Construction 2 07-11-2007 02:39 AM
Doors in a 1920's home samsays Remodeling 13 07-05-2007 10:50 PM
Attic Doors cyepsen Building & Construction 3 06-24-2007 07:47 AM
Painting Old Hollow Doors diywoman Painting 12 02-02-2007 07:52 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
