Trimming A Basement Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 04:33 PM   #1
Trimming a Basement Window
I want to get some opinions on my basement egress windows.
Picasa Web Albums - 10890264511619893...
My windows are about 4' square directly placed on the concrete. Last winter there was some condensation build up on the concrete around the windows. Note: the windows did not leak - it was definitely condensation. I will most likely trim out the windows with oak extension jambs. Here are my questions.
1) Should I use liquid nails to glue the jambs directly to the concrete?
2) Should I put poly film between the concrete and jambs?
3) Should I use pink foam/XPS to cover the concrete and insulate it - thus removing the cold surface and hopefully the condensation?
4) If I cover the concrete with anything, how do I make sure that the oak jambs are firmly attached? Just nail them?
Other ideas?
Thanks!
ShaneK is offline   Reply With Quote
Old 07-13-2010, 07:24 PM   #2
DIY staff
Rewards Points: 7,174
I suggest that you use 1/2 inch oak ply--3/4 solid oak will work --but may not allow for any gap between the concrete and the wood.
Your jamb extenders should be build like a box --then shimmed and nailed to the framing.
If sized right there will be room to spray some Great Stuff (blue can) into the gap.
Basement window jamb extenders require careful measuring--the windows are seldom plumb to the walls--the sides may have different measurements top and bottom.--Mike--
Tags
basement , trim , window
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Basement Window leaking suze0220 General DIY Discussions 8 08-06-2011 09:21 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 11:15 AM
Need a little advice replacing basement window Bcoleman6 Building & Construction 1 06-08-2008 06:49 AM
