Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-13-2009, 03:31 AM   #1
Trimmer joists-expanding a rough opening
To finish my basement ceiling without sacrificing ceiling height to a soffit, I intend to replace the copper drain for the toilet that juts below the ceiling plane and runs under the single header for the rough opening that accommodates the shower drain.
I intend to replace the elbow with a spigot closet bend to pull the drain into the joist bay (please see the notional drawing below). The trouble is that the header will be in the way of the raised drain.
I plan on removing the existing header, chopping the joists back beyond the closet bend, and putting in trimmer joists and a double header.
How do I wedge trimmer joists under the main girder? Does this plan sound viable?
This is the way things look right now (the trimmer joists don't exist):
benjamincall is offline   Reply With Quote
Old 05-13-2009, 11:18 AM   #2
Moderator
Single header and trimmer joists OK to 4' header span (UBC 2320.8.4)
Double header and trimmer when header spans >4' (UBC 2320.8.4)
I would add some 2x4, or 2x6 floor supports in that space to support the fixtures. Run them however you can, I recommend 12"o.c. Hangers wouldn't hurt. Be safe, G
Old 05-16-2009, 06:40 PM   #3
Drywall contractor
Just remember the "trap" for the shower drain HAS to be a certain depth below the tub/shower to operate properly to keep the "sewer gas" from backing up and to allow proper drainage. May not be an issue, but you may want to post on the plumbing forum if you need to raise it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Rough opening for bi-fold doors DCCook Building & Construction 6 03-20-2009 10:25 PM
Rough opening for door is 1/4" too small-what to do? Badfish740 Building & Construction 15 02-08-2009 11:05 PM
Opening Up Stairwell Wall jeffmn Remodeling 15 12-31-2008 06:21 PM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 09:01 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
