Trim Work - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 11:35 AM   #1
trim work
I just removed carpet that ran up the wall and refinished the hardwood floors. Around my door frames there is 1x4 oak that is squared off (not mitred). Will it look better to put up nice trim or should I just match up to the trim around the door. I do not want to remove what is already on the door frames. Thanks for the help
fredogg is offline   Reply With Quote
Old 01-06-2010, 03:20 PM   #2
CrossWorks's Avatar
Rewards Points: 150
A picture would be nice, but if I understand you correctly; your asking what type of baseboard trim to put on...correct?!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 01-06-2010, 07:21 PM   #3
Correct. It is just a plain 1x4 that is around the door frame now. I am wondering if I should just use the same material or if I should use more of a decorative trim. Thanks, sorry for the confusion.
Old 01-06-2010, 10:20 PM   #4
CrossWorks's Avatar
Rewards Points: 150
Well first thing and always is... consistency. Just keep the same type baseboard you have in other rooms in this one. If there is no consistency then use what you feel you may want to use in the future for other rooms. The most common baseboard here in New England is the 3-1/2 Colonial Base The pictures shows Oak but you can get the pine version at your local \lLumberyard. Don't go to the Box stores since they are more expensive (really!) and most times twisted/warped/bowed/orange/dented/dirty....you get the idea. They come clear pine or primed if your going to paint
So basically, you don't really have to use flat stock unless you want to stay consistent in that room only. Then just get some 1x5 oak (if your not painting) and stay consistent.Like I said earlier, match what's in the existing rooms first if all the other rooms have the same base. And if you do use clear oak trim, you can always ad a base cap (standard is the 1st one top left [FBC102] on the link)to spruce it up.
Old 01-07-2010, 11:32 AM   #5
Thanks for your help.
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Trim around a mirror? kimberland30 Carpentry 16 10-02-2008 10:57 AM
oil vs latex for trim work NoExperience Painting 7 08-31-2008 04:42 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
