Trim Selections-MDF? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 08:23 AM   #1
Trim selections-MDF?
Is MDF trim okay to use around windows? If a window is left open, do we need to worry about it taking on moisture? Will it support the weight of a curtain rod & draperies? Does it dent easily? If the door frame has to be ripped down, is the ripped edge ok to leave as-is? We are trying to save costs - what are the advantages/disadvantages of using MDF instead of wood?
steel1 is offline   Reply With Quote
Old 02-16-2009, 08:43 AM   #2
MDF is used a lot for trim, especially baseboard and wainscoting applications. I prefer not to use it at all but that is just my preference. If you buy preprimed material in pine I have a hard time understanding how you are going to save money by using MDF. I wouldn't use it around a window because of the moisture but then again, lots of people do. Buying preprimed and finished pine at a reasonable price will be more cost effective and time saving than buying the MDF and going through the work of ripping, sanding, priming, and painting. And most of the prefab MDF trims are really cheap looking...again just another viewpoint.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 02-16-2009, 11:10 AM   #3
SNC
i agree with jaros, use primed pine. I hate MDF and use it as a last resort. MDF is garbage.
SNC is offline   Reply With Quote
choosing right bulb and trim kit combo for recessed windowguy Electrical 3 11-29-2009 04:17 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
