Trim Popping - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 06:24 PM   #1
Trim popping
Hello,
Not sure if this is the right place. Feel free to move me. I was cleaning our family room today and noticed the trim on the right side of an interior door is separating from the wall. Easy enough to fix but I'm wondering what the cause might be so I can fix that too. The rest of the trim around the door is fine as is the rest of the trim around the house. Could it be the cheap-o IKEA baseboard expanding? That was my thought but I'm not an expert. Thanks for your input!! I'm in the SF Bay Area and it's a cool rainy day of which we haven't had many since we moved in.
Trim popping-image-2324711937.jpg   Trim popping-image-3358805277.jpg   Trim popping-image-2238905732.jpg   Trim popping-image-2875131357.jpg
MissKat is offline   Reply With Quote
Old 03-07-2013, 06:27 PM   #2
Here's a photo of the other side of the trim too.
You can see it's still intact.
Trim popping-image-1614367465.jpg   Trim popping-image-3286767778.jpg   Trim popping-image-83842602.jpg
Old 03-07-2013, 06:40 PM   #3
Rewards Points: 13,266
Looks like someone missed nailing or do not use long enough nails on the out side of the trim.
Cheap painters caulk will also do that.
kwikfishron (03-07-2013)
Old 03-07-2013, 07:52 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
it also looks old.. over time the paint will crack like that as the wood moves
woodworkbykirk is online now   Reply With Quote
Old 03-07-2013, 10:36 PM   #5
Hmm so just hammer it back in, re-caulk, paint and call it good?
Old 03-08-2013, 10:41 AM   #6
Rewards Points: 150
Yes and I agree with joec put in some longer nails n make sure u hit stud
kaschmid3 is offline   Reply With Quote
Old 03-08-2013, 11:03 AM   #7
Thanks everyone.
Old 03-08-2013, 12:28 PM   #8
Roofmaster
Rewards Points: 2,172
1. Earthquake.
2. Wind blow door closed "WHAM"
3. Somebody pissed, slam door "WHAM"
Trim pull away.
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 11:29 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
