Trim Out Options - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 09:57 AM   #1
Rewards Points: 14
Trim Out Options
Stumped on trimming out this opening. See Pic. Not a load bearing wall. My original plan was to make a very minimal (2 to 4 inches deep) faux beam across top of opening. Thinking about what to do after that then stumped me on how to trim out the remaining opening. Is it best to just leave it smooth ( patch in drywall, etc) or actually use trim running up to edge of faux beam. Maybe the faux beam is not a good idea. Maybe making a minimal header is best route. I am stumped.
Opening is drywall on one side and paneling on other.
What would the experts here suggest ? If you have any photos or links that would be greatly appreciated.
mannerofspeakin is offline   Reply With Quote
Old 01-06-2011, 10:08 AM   #2
Stay-at-home GC
It looks like the top and bottom plates are still in. Assuming the wall is running parallel to the ceiling joists (it better be, or your missing a header) You could add blocking between the ceiling joists, secure your top plate to the blocking at each end of the opening and remove the top plate.
Is the ceiling textured (popcorn, brush, trowel or other)? You'll have to add nailers for your drywall patch.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-06-2011, 10:15 AM   #3
Rewards Points: 14
Bottom plate is now gone. Wall is not load bearing as truss system above it. I left top plate in for possible nailing surface for faux beam. Ceiling Texture is brush/trowelish
Old 01-06-2011, 10:24 AM   #4
Stay-at-home GC
I would secure the wall top and remove the top plate.
Textured drywall isn't the easiest thing in the world to match but it will be less obvious than a faux beam
Old 01-06-2011, 01:13 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
If it were mine I would go with the beam as it would separate and define the two rooms unless the two rooms are meant to be an enlargement of one room. If I went with the beam I would drop it down enough to get a comfortable size ceiling mold up and still show a good margin.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-06-2011, 01:21 PM   #6
Rewards Points: 14
How far would you drop down ? There is already crown molding that runs the room. 3 inch molding or close to that. You would put in the beam and then add molding to it at ceiling ? Would you just finish the sides of opening with drywall patches ?
Old 01-06-2011, 01:34 PM   #7
Experienced
Jackofall1's Avatar
Drop it down far enough to install future french doors, always a nice feature between 2 rooms.
Old 01-06-2011, 02:58 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
In our house I dropped it so about 2 - 2 1/2 inches shows below the ceiling mold.
Jim
Fireplace trim options - hardwood floor joemontana16 Flooring 2 01-15-2010 03:28 PM
trim options for base as well as door frame reds_21 Interior Decorating 0 11-16-2009 08:10 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
