Trim Not Flush - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 12:11 PM   #1
Trim not Flush
Despite my contractors best efforts, there are certain areas in which my 1" x 4" hickory trim is not perfectly flush against the drywall behind it. I know cove moulding on top of the 1x4 would cover the gap. But I can't find cove moulding in hickory. I am looking for suggestions to solve this issue.
1. Alternatives to actual hickory for the cove moulding that will match well?
2. Wood putty or caulking in gaps?
3. Other?
ivanl3 is offline   Reply With Quote
Old 06-01-2010, 05:57 AM   #2
Walls/ceiling are NEVER flat or straight. Careful nailing can make trim fairly flush and tight, but caulk is usually needed for the final finish. If the trim is painted, a siliconized latex painters caulk is fine, if stained, there are colored caulks available.
Old 06-01-2010, 07:16 AM   #3
DIY staff
Rewards Points: 7,174
Walls are never flat--That is why thick,inflexible trims are often used with a second ,thinner flexible trim.
If caulking with a color matching caulk will not work for you---Make the trim your self with a table saw,surface planer and router---or special order the trim made from hickory.
A top trim carpenter will be able to make the trim-on the job or at his shop.----Mike----
Old 06-01-2010, 07:46 AM   #4
Trim not flush
Float out the gaps with drywall mud.
Houston_Bldr is offline   Reply With Quote
trim for doors that are flush with the wall aldous314 Carpentry 2 04-07-2010 10:44 AM
Recessed light trim not flush Jmcc64 Electrical 1 04-06-2010 01:17 PM
door trim not lying flush to frame mayhem69 General DIY Discussions 4 12-31-2009 08:32 PM
Electric Flush Cut Trim Saw Bill T Flooring 6 12-01-2009 05:44 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
