Trim Nailing A Door Jamb To Framing - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 02:27 PM   #1
Rewards Points: 1,062
trim nailing a door jamb to framing
this seems kind of trite but how should i nail a door jamb to the framing, i.e. at which spacing should i set the nails in (e.g. 4, 8, of however many inches between), and should i use 1 or 2 trim nails at every step ?
Old 01-24-2011, 04:03 PM   #2
Exterior or interior doors? Rabbeted jam or flat stock with a stop on it? Prehung?
Shim in four or five places ,nail through the shims on each side of the jam to prevent twisting, score and snap, 2" nails as you will have at least 3/4 of material and a 1/4 space to go through before reaching the framing. Dont forget the casing will also help to hold things in place. You can also shim where the hinge is and replace one of the screws in each hinge with a longer one to hold more securely. Shim where the latch hits the striker plate. There are also ways to do blind nailing with some jams to make life easier on the finishers or painters.
masterofall is offline   Reply With Quote
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
