Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-28-2010, 09:15 PM   #1
Trim and Molding Questions
I'm installing new baseboard molding and trim with rosettes in my dining room. I haven't done this before so I have a couple of questions.
What is the tool I should use to install trim and molding?
Another question, should I paint the trim before I install it or after?
tdeepness is offline   Reply With Quote
Old 04-29-2010, 07:03 AM   #2
Hard woods like oak need to be predrilled when nailing, or use 15 or 16 ga. nail guns. If you are painting, I would prime all sides first, then paint once installed. You will have nail holes to fill, which should be done before painting. If staining, stain first, poly after installed. And don't forget caulk before finishing. Use a matching caulk for stained wood.
Old 04-29-2010, 07:22 AM   #3
Man of many hats
wrangler's Avatar
You can also paint you trim first, install, fill your nail holes and joints and then do touch up painting.
Man of many hats
wrangler is offline   Reply With Quote
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
Satin or Semi-Gloss Paint for Molding and Trim? tdeepness Painting 4 03-29-2010 09:59 PM
Hang a mirror by crown molding / trim? kennedy.greg Carpentry 1 03-22-2010 05:46 PM
Installing ceiling trim with uneven ceiling. capslock Carpentry 3 03-21-2010 12:53 AM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
