Trim Molding-Which Is Less Expensive? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-27-2008, 08:56 AM   #1
Trim Molding-Which is less expensive?
I'm trimming out a small guest house and was thinking about using 1x4s for the trim. Is this less expensive than going with actual trim molding?
Randell Tarin is offline   Reply With Quote
Old 05-27-2008, 10:10 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Standard base and case molding are not much different in cost that good quality 1 by 4 pine. Using 1 by 4 will give a more rustic look. If you are going for cheap, use MDF (Medium density fiberboard) base and casing. Most lumber yards carry it, also the big box stores.
Old 05-27-2008, 10:11 AM   #3
Jay123's Avatar
It will depend on what the 1x4 is...mdf, pine, oak, walnut...
I'd check you local big box - for a small house, paint-grade trim should be pretty inexpensive.
J
Jay123 is offline   Reply With Quote
Old 05-27-2008, 08:57 PM   #4
remodeling pro
Unless you want the look of flat stock, it will be less expensive to buy a paint grade , finger jointed profiled molding from the lumber yard. Unless you are looking for a log cabin rustic look, you will have to buy #1 pine or poplar stock; lesser pine grade will be full of knots and is not suitable for painting.
troubleseeker is offline   Reply With Quote
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 05:48 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 10:12 PM
